I payed a lot of money to have my ac rebilt in my car my question is will my ac work and bolt on my b20a the same way as the a20a it gets hot in CA in the summer thanks :smokin:
FUN IN THE SUN IN MY LXI BOLINKXR
b20a dc header, cat back ,tokico springs, mugen intake ,full msd vortec fuel pressure regulator, sei disk brakes, 16" rims reverse indiglo gages, 4wS pralude stering wheel
The bracket part numbers are different if I remember right. I don't have A/C right now and the B20 motor I have only came with the AC bracket so I have nothing to compare it to. I can check if the bracket holes line up on the A20 but that doesn't mean the compressor pulley will line up with the crank pulley.
www.b20accord.com
The A20 compressor won't bolt up to the B20A. You will have fabricate your own bracket if you want A/C. That's what i'll be doing next spring!!
Major modifications include:
JDM Accord B20A engine swap
89 SEi rear disc conversion
3geez member since Aug 18, 2000
I have a B20a compressor from my 2.0i-16.
The power steering pump uses the top air con compressor mount on my B20a.
My aerodeck doesn't have air con (no need for it in the UK).
I'd hate to think how much shipping would be as its expensive enough for small stuff.
Honda CR-V Mk2
Quantum Sport Saloon
cool thanks for the help
