Results 1 to 10 of 10
Thread: Tach reads too high
    '89 SEi Coupe
    Question Tach reads too high
    The tachometer on my '89 SE-i Coupe 5-sp always reads too high. When warmed up, the idle reads about 1200 RPM when the actual speed is 500-700. At freeway speeds, it seems to be about 1000 RPM too high. These figures have been verified by two different shops.
    This car is new-to-me. I have no idea what the previous owners might have done. Any ideas?
    Thanks, Cap
    if it idles at 1200, you may want to turn it down a little.
    when did you buy this car?
    '89 SEi Coupe
    I guess I wasn't clear
    This tach does not read the true engine RPM.
    The tach indicates the actual engine RPM PLUS an additional, erroneous, 500-1000 RPM.
    My question is, what would make the tach reading false?
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    i dunno but a 5 inch monstar tach with external shift light is only 100 bux at Jegs or Summit! hook one up.
    Travis
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    any erratic prob's with any of the other gauges?
    10/Honda/Ridgeline
    NJ
    it maybe cause someone or the previou owner might have taken it out and when the put the tach back in the needle was off. Try changing just the tach from the junk, just try it, u dont have to buy it like try fixiing it and see if it does the same. I don tknow any junk yard u know would do it, but the somerset wreckers and recyling (junkyard attached) that i go to. the dude always allows me to test it before i get it.
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    does it read 0 when the car is off ?
    Jay
    Oct 2001
    87 Accord EX , 5spd , Manual
    does it read 2750 when doing 60 mph @ 5th gear !
    MIKE
    '89 SEi Coupe
    The tach reads 0 when the engine is not running.
    In 5th, at 70mph, it reads about 4000.
    No, the clutch is not slipping.
    When getting the emmissions checked, the mechanic noted the the tach was not properly calibrated. Later, when getting a tuneup, a different mechanic noted that the tach was not properly calibrated.
    How does one correct the calibration of a 3g Accord tachometer?
    1988starter
    Guest
    try switching out you ignition coil
  1. Tachometer Reads Too High
    By marklj in forum 3geez Accords
    Last Post: 01-25-2025, 03:24 PM
  2. MSD tach adapter driving stock tach
    Last Post: 05-11-2008, 09:57 PM
  3. Failed Emissions: High HC ppm's & High CO%
    By 98serwtricks in forum 3geez Accords
    Last Post: 06-15-2004, 09:24 AM
  4. new tach
    By 90CRX in forum 3geez Accords
    Last Post: 03-17-2003, 09:34 PM
  5. tach
    By si accord in forum Classic Honda Community Chat
    Last Post: 12-18-2002, 08:08 PM
