Results 1 to 6 of 6
Thread: Question for Carb to EFI conversion
    Oct 2002
    1988 Accord LX
    Vancouver
    I have a question for Carotman and all those who converted to EFI. I noticed in Carotman's how to, he added a third line to accomodated the fuel return line. So I have 3 questions.
    1. How did you SAFELY add the third fuel line? Did you drill or weld?
    2. In the how-to it mentions the gas tank has special chambers in it. Does this mean i'm going to have to replace my fuel tank? Or will it not make a difference if I just add the third fuel line?
    3. I forgot what the 3rd one was. OH ya! I was hearing somewhere that I needed higher pressure fuel lines, so am I going to have to replace my existing ones?
    I'm so wanting to convert to EFI this spring so i'd apreciate and info! Thanks.
    1988 Accord LX, Bosch Wires, NGK Plugs, K&N Filter, bla bla bla
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    If I remember right you need all the fuel lines and fuel tank to get it to really work right. Without those chambers the pump may run dry during hard cornering and you'll kill the engine.
    Mike
    accord HB ( metallic green)
    B.C Chilliwack
    Well ya need a high pressure fuel feed line ( this is the extra line you have to run) the new efi fuel pump has the extra hole for the extra line, run it along the drivers side under the dash and you will need to drill a hole in the firewall for the line.
    As for the tank it is reccomended to swap it out, I haven't yet but will in the spring cause I don't like cornering hard under 3/8 of a tank cause ya feel the pump sputter.
    As for the feul line you can use a stock one from the wrecker or just buy the hose from a parts store and you will also need 2 connecters for both ends of the line - hope that helps
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    Oct 2002
    1988 Accord LX
    Vancouver
    Yep, that answers my questions, thanks!
    carotman's Avatar
    Montreal South Shore
    I couldn't answer better
    The EFI return line is actually the carb feed line You just invert the flow hehe
    I need these parts!
    10/Honda/Ridgeline
    NJ
    dammit i was baout to answer this thread, but shit i am too late
  1. CARB TO EFI / EFI TO CARB Distributor Conversion
    By A20A1 in forum Carburetor Tech
    Last Post: 08-29-2006, 06:08 PM
  2. 2G carb to EFI conversion?
    By Coy in forum 2geez Accords
    Last Post: 03-28-2006, 11:03 PM
  3. b20a carb conversion
    By rjudgey in forum Performance
    Last Post: 02-22-2004, 12:09 PM
  4. carb to efi conversion
    By Mantis88LX in forum Classic Honda Community Chat
    Last Post: 08-15-2002, 06:14 AM
  5. Carb conversion?
    By CoAsTeR in forum General Engine Swaps
    Last Post: 06-01-2002, 10:37 AM
