Results 1 to 4 of 4
Thread: bad balljoints affect camber?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    ok my car is lowered 2'' with no camber kit, the drivers side has camber but the passenger side doesnt have as much as the driver side, and the passenger side upper balljoint boot is ripped and starting to knock, could the balljoint be the reason?>
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Very difficult to say. The balljoint might be the reason if it is loose and can move the whole knuckle out. Did you have this problem after lowering it or only now? And how long has it been lowered without camber correction? Check your tires, that's a good indication.
    But above all, have that upper arm/balljoint replaced.
    Banned
    Morgantown, West Virginia
    If I remember correctly, didnt you lower your car without taking it in to get an alignment?
    Nate.
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    Yes.
    When I had a bad upper ball joint the wheel was noticeably tipped in much more than the other side and when I replaced it the problem was gone. You should be able to jack up the car and feel the looseness in the ball joint.
  1. how can the carb affect the oil pressure ?
    By ekoms in forum 2geez Accords
    Last Post: 11-17-2009, 01:32 PM
  2. Ign. Coil - affect on Fuel Pump ?
    By Lester Lugnut in forum 3geez Accords
    Last Post: 01-20-2006, 10:24 AM
  3. balljoints
    By lightbulblxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-30-2004, 09:15 PM
  4. question about ground affect's
    By accordlxi2.0 in forum Interior & Exterior Care
    Last Post: 11-27-2003, 06:36 PM
  5. balljoints effect camber
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-18-2003, 01:51 PM
