Results 1 to 9 of 9
Thread: 89' Accord LX shuddering really bad and always stuck in gear
    DX User devyndavis17's Avatar
    Oct 2013
    1989 Honda Accord LX
    Blaine, Washington, United States
    Ok back in November i was driving my 1989 Accord LX up the road by my house and right as i got passed my street the car started shuddering really bad and almost died on me. When it started to shudder as hard as it did i thought i busted a CV joint or blew the motor. I was able to limp it home but ever since that happened it has been stuck in Drive no matter what gear i put it in and when ever i go to move it, sometimes it will shudder really bad or it just won't move at all. Has anyone else had this problem before?
    Jan 2013
    1989 Honda Accord LXi
    Hemet, CA
    Re: 89' Accord LX shuddering really bad and always stuck in gear
    Have you checked your transmission fluid level?
    Sounds lke tv cable popped off or brokr or stuck too
    I'm guessing there is some very expensive valve body damage deep inside the transmission.
    Oct 2013
    TV cable is still connected and Fluid is at a normal level
    Does the lever down on the trans (under battery towards bell hsg) move when the throttle moves? It has to move as the gas pedal moves, kind of a primative non electronic throttle position sensor for the trans, a section of the valve body needs it to be adjusted correctly and functioning to determine internal pressure routing to provide correct gear.
    Oct 2013
    I tried to adjust the TV cable and nothing changed. every time i add fluid it's like a bottomless pit because the level stays the same. Could it be a Torque Converter seal? It also feels really tight when i shift and when i put it in Park the light doesn't come on right away. i have to jiggle the shifter and press the brakes for it to come on
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    How does the fluid look?
    Oct 2013
    last time i checked it looked grayish and then i added Automatic Transmission Fluid and it was purplish
  1. b20a manual transmission gets stuck in/out of gear
    By 3gmodifier in forum JDM B18A / B20A Swap Tech
    Last Post: 03-23-2014, 12:46 AM
  2. Last gear is funny after stuck in deep snow
    By robear in forum 3geez Accords
    Last Post: 01-14-2009, 11:40 PM
  3. 86 accord lxi rear brake drums stuck.
    By moonjaw2002 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-22-2007, 06:25 PM
  4. My accord is so stuck in a 3 foot snow drift!!!
    By Mike's89AccordLX in forum Classic Honda Community Chat
    Last Post: 03-19-2005, 09:43 AM
  5. Shuddering in gear??
    By viking3099 in forum 3geez Accords
    Last Post: 06-15-2004, 05:31 PM
