Ok I put this together in a effort to track down all the 86-89 and 90-97 coilover kits that I could find. I have not yet contacted any of the companies, so if their spring rates are not listed in the "spring stiffness" post, I do not know them,...yet.
I have provided all the info I could get so far, including each companies run down of their own product. I will edit and up date the info as I can do so. If you know of a brand not listed, please pm me with that info.
skunk2 coilovers:90-97 accord $299.00 www.nopionline.com
http://www.skunk2.com/start.htm
[email protected]
909-808-9888
Skunk-2 springs are CNC hot rolled using SUP12 alloy spring steel, heat treated,stress relieved, pre-set, phosphate treated, powder coated, and finally printedwith the Skunk-2 logo. Hot rolling produces a spring with a consistent grain structure that is extremely resilient and will not deform or change rate. The
combination of hot rolling and using only the highest quality alloy wire results in a spring with superior performance and ride characteristics. For increased strength, the dual spring perches are CNC machined from hot forged AL6061-T6. SkunkWorks Coil-Over kits allow you to adjust your ride height anytime you want. They provide more suspension travel and therefore will ride
better than a normal lowering spring, even at extremely lowsettings.
Tenzo Racing Coilover:90-97 accord$230 www.crveverything.com
www.tenzoracingsports.com/
Tenzo-R Coilovers are precision engineered to maximize your suspension performance. Carefully matched spring rates and height adjustability provide exceptional handling, response, control and balance. Increased spring rates combined with the ability to lower the center of gravity helps reduce body roll and
optimize power transfer. Comes complete with everything you need for easy installation. Anti-locking Teflon O-rings assist the wrench tool for easy height adjusting.
Autotech Systems and Accessories
20758 Centre Point Parkway
Santa Clarita, CA 91350
HOURS :: 9:00am to 5:00pm (Monday to Friday)
TEL :: 1-661-250-3000
EMAIL :: [email protected]
TECHNICAL INQUIRIES :: [email protected]
TSUDO coilover 90-97 accord $161.82 www.nopionline.com
Sleeve and Spring Coil Over Kit - Lowers from 4.5" to 1" Front and Back - Set
#1 coilover 90-97 accord $136.36 www.nopionline.com
Sleeve & Spring Coil-Over Suspension Kit -Lowers 0" to 3" (fits shock absorber - OE, KYB, Koni and Tokico type)
RACER DESIGN coilover 90-97 accord $144.44 www.nopionline.com
Sleeve and Spring Coil-Over Suspension Kit -
Front and Rear - Lowers 0"-4" - Set of 4 - TITANIUM
APC coilover 90-97 accord $179.25 www.nopionline.com
Sleeve & Spring Coil-Over Kit
HP RACING 90-97 accord $139.66 www.nopionline.com
http://www.hpracing.com/
[email protected]
hurrican power inc,
1-800-522-7855
Sleeve and Spring Coil-Over System - Adjusts 0" to 4" Front and Back-Polyurethane Bushings Gen1 Coil-Over Kits: The Gen1 Coil-over kits from HP Racing offer adjustable ride height from 0-4 inches. Each application has it's own spring rate to ensure a good ride and tight suspension to prevent the kits from vibrating and creating road noise. Heat-treated coils prevent springs from settling and corrosion.
dropzone coilovers 86-89 accord $107
http://www.dropzonesuspension.com/
1-888-800-0051
[email protected]
http://www.dynamicautodesign.com/coilovers.htm $107
http://www.ketronsales.com/coilovers.html $99
dropzone springs 86-89 accord $101 model # shown is DZ1002
http://www.dynamicautodesign.com/springs.htm $101
Ground-control 86-89 coilovers drop range 0" to 3" $329
www.nopionline.com
www.ground-control.com
1-530-677-8600
part#4505.01
Arospeed Coilovers 90-97 accord $149.95 free shipping?
www.streetbeatcustoms.com/arcoilhonac9.html
http://www.arospeed.com
1-800-276-7733
1-305-969-9973
[email protected]
part# ARO660014
Arospeed Coiloversare designed to give you the look you want with the performance you desire. Arospeed springs are linear rate and offer up to 4 inches of adjustability. Height is adjusted through use of a threaded sleeve that fits over
OBX gravitational coil over 90-97 accord $174
part#HK06
www.massivemotorsports.com/main/allcoilovers.htm
http://www.obxracingsports.com/perfo...=4&subCat2ID=2
OUTBACK PRODUCTS, INC. U.S.A.
Fax: (650) 873-8802
Email us: [email protected]
desighned from extensive circuit race testing. Developed in conjuction with one of the largest OEM suppliers. Ride height adjustable suspension kits keep vehicle weight distribution balance and will improve on HARD cornering and braking,
without having the front suspension taking a nosedive. This kit draws out maximum performance of the car! your stock or aftermarket shocks and a dual locking perch mechanism. The kit includes 4 threaded sleeves, 4 pairs of locking perches, 4 linear rate springs, 4 urethane bushings, and 2 adjuster tools.
MaxSpeed Coilover Accord 90-97 $219.95
http://shop.store.yahoo.com/racinglab/honac90maxco.html
Racing Single Generation 3 Coilover 90-97 accord $159.99 free shipping
http://www.gochargeit.com/enetgroup/....htm?add+CO200
Titanium High performance coilover systems feature progressive rate spring for a comfortable ride, while offering much-improved handling and style.You can adjust your ride height from 0-4 inches and anywhere in between. It is easy to adjust!
The ride quality is much better than most coilovers because of the added bushings, and high spring rate. If you want high quality at a good price this is your best buy!
R1 RACING SINGLE COILOVERS 90-97 accord
http://www.showtime-video.com/sincoil.html $229
R1 high performance coilover systems feature progressive rate springs for a comfortable ride, while offering much-improved handling and style...Fully adjustable ride height up to 4-inch drop. Free Shipping and handling.
