Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 140
Thread: Aaron's ITR!
    Aaron's ITR!
    pics are dead so this thread can be deleted
    Re: Aaron's ITR!
    It's a type type R :O
    Re: Aaron's ITR!
    indeed. extra RRRRRRRRRRRRRRRRRRRRrrr
    i may put some wheels on it later so i can wheel it around
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Re: Aaron's ITR!
    Always keeping busy!
    Andrew.
    Re: Aaron's ITR!
    wheels are on, Konis are in. fail is found
    dash is out and so is the old heater and old OBD2 wiring thats no longer required.
    New OBD1 dc2 loom with climate control. flash!
    Re: Aaron's ITR!
    wow it totally looks like the RR hub is so bent that you can't even fit the factory wheel on it, or even a space saver, so it looks like you had to bolt the space saver on backwards!
    Re: Aaron's ITR!
    im gunna do skids on that space saver when its going(Y)
    Re: Aaron's ITR!
    First person ever to convert a Type R to 4x100.
    Pretty clean shell though. Sucks that they painted the decklid black, considering the jams are white. People are idiots.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Re: Aaron's ITR!
    ^ That, next thing he will do is swap in a D16z
    '88 LX-i Coupe --- LS/Vtec
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: Aaron's ITR!
    D series b jdm
    -Gio
    My E85 Turbo Build
    5280FEST
    Re: Aaron's ITR!
    i can only imagine how slow it would be with a d series. i have a b20b and vtec head to go on it later on..
    Re: Aaron's ITR!
    amazing project Aaron, you have it wide open so you could put any crazy combination you want in that!
    Re: Aaron's ITR!
    moar progress tonight. ripped out old loom and put in new climate control heater boxes to replace the shitty old dial heater controls. and the OBD1 wiring loom (ITR is OBD2 which is useless to me)
    dash is now sitting in place.
    A Mile High.
    Re: Aaron's ITR!
    Throw a j35 in there
    -Gio
    My E85 Turbo Build
    5280FEST
    Re: Aaron's ITR!
    Agreed .
    AZ
    Re: Aaron's ITR!
    X3.
    dead white and blue
    carotman's Avatar
    Montreal South Shore
    Re: Aaron's ITR!
    Hey a 4 lug ITR (4x114.3)
    DX User scanlessfool's Avatar
    Dec 2011
    East of the 6th St. Bridge
    Re: Aaron's ITR!
    This looks like it is going to be a long endeavor, but as long as you are not in a rush, I'm sure it will come out just fine.
    Do It Once, Do It Right!
    Re: Aaron's ITR!
    i cannot put another engine in without having to "re-cert" the vehicle which costs a fuckload. its gunna stay b series.
    Dec 2011
    Re: Aaron's ITR!
    I know that Australia has very stringent rules for any modified vehicle, but would this also be the case for New Zealand?
    Re: Aaron's ITR!
    i think aussie is worce. over here you can get away with mods if the car is certified as safe by a registered certifier guy that charges you 400 bucks and tells you to put in a CAT then you get a plate riveted to your engine bay that tells you what engine and suspension and wheels you MUST have to pass wof. and if you change any of those a re-cert is required. fuck that, im keeping it b series haha
    Re: Aaron's ITR!
    so since it already has a cert for adjusties, wouldn't you 'legally' need teh sized wheels that the cert tag thingy says?
    Re: Aaron's ITR!
    cert plate will be removed. even then all it says on the cert is OE engine OE wheels and adjustable suspension. if i ever get 'justiez ill rivit it back on
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Re: Aaron's ITR!
    Little by little will get it done!
    1989 Honda Accord LX-I 300K+
    Build Thread
    Re: Aaron's ITR!
    big update. the interior is in and i have borrowed an engine so i could drive it to auckland and pick up a new pair of doors. no more bog filled rusting door!
    pics:
    sir interior installed. will do for now
    body is rough here and there, will require a WHITE bootlid at some stage and maybe a new bonnet as theres a ugly dent in the front of this one, both bumpers also need attention too. teks Hard boi
    temporary engine, original B18CR, used about a litre of oil going to auckland and back, smokes like a bitch. cant expect too much the cars had a hard life and done 210000kms
    running OBD1 with a chipped P08 and a stock crome b18cr map. Engine is mated to a open diff Y21 gearbox i got for $80 from a EG9. Had a fucked diff so i swapped another open diff in for now as i was in a hurry to get the car working. i have a ITR LSD to put into this box eventually.
    Mugen power. 4-1 header into 2.5" jasma plated mandrel exhaust system and out a FGK muffler,sounds way better than the shit ass fart can it used to have.
    got 4 new tyres going on the dc2 wheels this saturday!
    awesome. Next step: B20VTEC...........
  1. Aaron has another accord
    Last Post: 01-27-2010, 10:30 PM
  2. Aaron Wier ROCKS!
    Last Post: 12-28-2007, 05:47 AM
