Results 1 to 4 of 4
Thread: Upcoming Springtime Fun!
    Jul 2009
    Somerville, Alabama
    Well, I've got a few projects on the back-burner ATM, as it tends to stay around the low 40's to high 30's Fahrenheit in Alabama. Springtime is approaching and I have several goals to be completed by the end of Spring and others by the end of Summer. A few of you know, Within the week, i should be a dad of one of our future members so progress may go slower than i thought previously. Here are a few things:
    To be finished by the end of spring:
    -Front Lower Control Arm Bushings
    Part Number: 8210
    Manufacturer: Prothane
    (I have new bushings installed that aren't but a few months old. At the time of ordering though, i was not aware Prothane made these bushings. I got rubber stock ones from rockauto.com for $1.50 each. These would be better off poly)
    -Rear Lower Control Arm Bushings
    Part Number: 8312
    (I have new bushings installed that aren't but a few months old. At the time of ordering though, i was not aware Prothane made these bushings. I got rubber stock ones from rockauto.com for $3.50 each. These would be better off poly)
    -Front Shock Mount Bushings
    Part Number: 8907
    (I have new bushings installed that aren't but a few months old. At the time of ordering though, i was not aware Prothane made these bushings. I got rubber stock ones from rockauto.com for $5.94 each. These would be better off poly)
    -Transmission Gear Selector Bushings-These will have to be made, obviously. I have so much slop in the shift knob/arm. I was thinking of just ordering a poly rod the right ID of the arm on the transmission and just drilling out a center hole and cutting to size. I'll take pictures if this is what happens.
    By the end of summer i plan on having this car swapped to OBD1 and tuned via crome(Buddy has the paid version with everything unlocked). Still got alot of reading up to do on that part though...and i'd much prefer to find a runnable .bin file already made for it's first flash, then tune everything from there. I'm sure there's a large learning curve there though.
    Gotta attain this though first:
    Xenocron Tuning: Chipped OBD1 Non-VTEC Honda ECU. #[Non-V-Ecu] <---OBD1 chipped ECU
    Xenocron Tuning: ECU Conversion Harness - OBD0 to OBD1 #[OBD0-1harnes] <---OBD0 to OBD1 conversion harness
    Xenocron Tuning: Fuel Management and DIY Tuning Resource Center for Honda and Acura Performance - Hondata, eCtune, Neptune, Crome, TurboEdit, Uberdata <---OBD1 TD41U dizzy(May already have found one good/used for $40)
    Xenocron Tuning Solutions: Wideband O2 Air/Fuel UEGO Gauge Kit <--- AEM wideband AFR gauge
    And we'll see where it goes from there.
    Shaggy
    FF II/ETC I
    Re: Upcoming Springtime Fun!
    Cool stuff! Keep us posted on your progress and congrats on the new arrival.
    U mean shifter bushings? There is a part number floating around for them. Ill I'll post it up tomorrow.
    But good deal. How are u going to mount the dizzy?
    redneck's Avatar
    May 2012
    08 tsx,89 sei coupe, 88 lxi sedan
    lexington, sc
    that would be da shifter bushings, have them in my car with a dual bend. and steve i have priced out all of the suspension bushings and you can get just about everything off ebay.
    energy suspension.
    shift linkage 16-1101
  1. pictures of my ride this upcoming week
    By newaccorddriver in forum Classic Honda Pics & Videos
    Last Post: 06-30-2007, 01:39 PM
  2. possible springtime meet in northeast??
    By cubert in forum Classic Honda Community Chat
    Last Post: 02-28-2007, 07:11 AM
  3. Some advice needed for an upcoming 3g owner..
    By Acid X in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-23-2005, 02:13 AM
  4. Upcoming Clutch Replacement
    By 89LxiAg in forum 3geez Accords
    Last Post: 07-09-2003, 05:07 PM
