I've finally got all the parts to start to build my manifold, so here is my first installment on how to do it.
The A20A DCOE manifold how to part 1: Getting your shit together.
The parts list for this is pretty short. All parts are aluminum to make the fabrication easier.
- 2 DCOE flanges. They are available from Pierce Manifolds. They are not listed in the catalog but the part number is 99005.147. These puppies are $42 a pop, but they make for a nice clean well fitting manifold.
- Tube. Onlinemetals.com is a good source, resonable prices and they deal in small quanties. Figure on about 2 feet of thick walled tubeing. I bought some 1/4" walled tube, and its a bit too thick, but don't go thinner then 1/8" this has to stand up to the vibrations of the engine. The tube should be about the diameter of the throttle plate of the carb. For a 40DCOE thats about 1 1/5", for a 45 just do the math.
- A flange to fit the head. The easiest way to get this is to just cut it off your old carbed manifold, or a spare one if you are still driveing the car while doing this. Don't use an injected manifold because you would have to plug up the ports for the injectors. Thats just more work for you.
The only real work thats been done so far is to chop up my spare manifold. I'm sure you can figure this out on your own but here it is anyway.
Mount the manifold in a vice.
Choose your weapon, this can mean the diference between this taking 5 or 50 minutes. Which do you think I chose?
When you're all done you should end up with something that looks like this.
And you can just throw this part away.
Next time I will be back with making the runners and maybe start the fitting.
andy
