Results 1 to 9 of 9
Thread: starting problem,or clutch problem
    Oct 2002
    1987 Honda Acoord Lxi HB
    Knoxville,TN
    On my '87 lxi I can put the car in neutral and without pushing in the clutch the car will start, if in gear it will lurch foward without pushing in the clutch. I've had several straight shifts before and none would do this not even my '91 accord, so is this normal for this car or is somthing wrong?
    1986 accord lx-i HB 5 spd, 1988 prelude Si 5spd
    Raleigh, NC
    my '86 lx-i does the same thing, if that's any help
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    I'm pretty sure that's normal. Mine does the same thing as well.
    Alex
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    there is a clutch start switch. if it breaks or gets disconected, you can start the car in Neutral. if not, you must push in the clutch. its a safety thang and most older cars have theres broken or removed.
    Travis
    Oct 2001
    87 Accord EX , 5spd , Manual
    you guys kiddin !?
    you mean that it lurch forward when starting in gear !??
    that's normal , very normal ! beacuse when you start your engine the flywheel turns so the clutch disc turns , so if in gear it will try to turn the wheels too but it doesn't have enough power so it just lurchs forward !
    MIKE
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    remember those sears diehard commercials were they freeze a car in a block of ice and then start it? they thought that was a real test of a batteries strength. back in the late sixties me and my friends would race our VWs using just the starter motor. we'd take out the plugs and then line up in the school parking lot and see how many laps we could do before either the starter burned out or the battery died. It was great fun. those were our first electric cars, me and my buds were bleeding edge freaks. everything was so cheap then it was all about experimentation.
    Nov 2002
    Ridin Dirty in New York
    Yeah its normal to be able to start these cars without touching the clutch... just push down the pedal before you start, no biggie. It woke me up in the morning when i forgot to do it... it makes life interesting
    shepherd79's Avatar
    Falling Waters, WV USA
    i don't think we have this clutch switch, or at least i don't have on m car. i know Toyota put them on eevry car.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I know I have one. It still works too.
    Mike
  1. another starting problem..
    By maka_RTH in forum 3geez Accords
    Last Post: 12-23-2005, 12:47 AM
  2. Replies: 7
    Last Post: 08-11-2005, 04:17 PM
  3. Whats wrong with my car? hesitation problem & starting problem!
    By gsus in forum Classic Honda Community Chat
    Last Post: 08-11-2005, 08:04 AM
  4. starting problem when wet
    By pratman in forum 3geez Accords
    Last Post: 10-16-2003, 06:22 PM
  5. Starting / Clutch Problem?
    By 89AccordLvr in forum 3geez Accords
    Last Post: 08-18-2003, 06:37 PM
