When you changed from Auto to 5 Speed did you change the exhaust heat sheild that goes over the part of the gear change that bolts to the floor?
I have started my B20a swap (swaping to 5 speed from auto at the same time). I will be ready to pull the A20a2 out tommorow (weather permiting)
Am I going to have to change/remove part of the heat sheild?
Is there enough room for the gear change rods with the Auto heat sheild & are there going to be any problems bolting the gear change in place of the auto selector housing?
