Results 1 to 6 of 6
Thread: Carb issues? HELP!
    Feb 2014
    1984 Honda Prelude
    Carb issues? HELP!
    Hi! I have an 84 Prelude and its acting up. It sounds like its choking, spits, sputters, and sounds like a subaru untill I hit WOT and around 2500 rpm,en I do it pulls like a raped ape most of the time. It does have a bad head gasket but its so so bad that I thing its causing compression issues. This issue came about after I sprayed a little carb cleaner in the carb after changing the oil as part of a tune up. ANY help is so greatly appreciated!
    Re: Carb issues? HELP!
    I think that head gasket is the place to start. If the issue remains after that, then we can go from there.
    It could be you dislodged some dirt and crap in the carb by spraying the carb cleaner and its now clogging some passage or something because you said it happens right after that. How do you know that you have a bad headgasket?
    Wow an 84, may have rust in the tank and who knows what, complete fuel system cleaning wouldnt hurt
    Feb 2014
    1984 Honda Prelude
    I meant to say its not so bad that its causing compression issues. It uses water and it comes out the tail pipe. I'm gonna do the head gasket tomorrow and clean the carbs out really well while im at it. Its much much worse today. It barely wants to run but it sounds like the carbs are suuuuper clogged up. Thanks for the tips everyone! Also does anyone know much about doing an emissions and vacuum delete?
    It could be the headgasket getting a lot worse now and it refuses to run at all. Can't help much with the emission and vaccum stuff but this might help if you haven't seen it Untangling the spaghetti and removing unnecessaries... - Honda Prelude Forum : Honda Prelude Forums
    Also, I'd check the pistons and make sure they slide up/down smoothly. Mine would get stuck at 1/4 opening randomly and the car would run weird with it. You really have to clean the pistons out and even the tiniest bit of crap would get it stuck or not moving properly
  1. carb idle issues caused by carb temp sensor discuss
    By lostforawhile in forum Carburetor Tech
    Last Post: 01-28-2017, 01:51 AM
  2. Help carb gods! I need help! Carb has issues!!!!!
    By 86ccord in forum Carburetor Tech
    Last Post: 03-03-2011, 05:13 AM
  3. Carb Issues...
    By tedhodges in forum Carburetor Tech
    Last Post: 01-14-2010, 07:27 PM
  4. Serious Carb issues
    By RJ-92 in forum Carburetor Tech
    Last Post: 02-23-2004, 03:06 AM
  5. Serious carb issues, 88 LX 4dr, Help!!!
    By ascender in forum Carburetor Tech
    Last Post: 03-12-2003, 09:14 PM
