Hello everyone,
I have recently aquired a 1989 Accord LX and have already found something that I can't resist messing with. When I got the car, the antenna mast was kinked but not broken right where it exits the housing. I found a proper replacement mast at the local Automotive supply store but I found that I could not remove the old antenna. Once I remove the two screws that secure the top cover of the assembly, I can pull the antenna and it's housing out for about an inch, beyond that it will not move. I have not had a chance yet to get to the antenna motor but will try that soon. Is the antenna secured to the motor and therefore is impossible to remove without messing with the linkage down there under the dash? Can someone explain how and where the antenna is mounted to the body/car/dash? I have searched this board for an explanation and haven't found anything regarding this problem. I have also looked at the shop manual and that only explains motor and switch testing. Any help regarding this problem is apreciated. Thanks in advance.
The RUS. :pimp:
