Results 1 to 8 of 8
Thread: MSD SCI Ignition
    LX User Nate2310's Avatar
    Oct 2002
    MSD SCI Ignition
    Does anyone have the MSD SCI Ignition? What kind of difference or gains did it give you?
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    I got the MSD 6A, but it's basicly the same, just a new box. Gains were good in the upper RPM bands above 4,000 - the "pull" didn't feel like it was leaning out. I also got the standard I/H/Rusted-E, so that helps.
    You got an LX, so I don't know how much of a difference it would help on yours. I'd get a Weber conversion for that money; more power there.
    I am the wrath of the server you curse and the demon of the directory you cry about - making life hell for users, one deleted file at a time.
    1989 Honda Accord SE-I
    Texas Hill Country
    Have you gotten any arcing in the distributor with the MSD 6A's 20 degree spark duration? Also, do you guys know if the SCI has a shorter spark duration? Also, what coil are you using? I am using a 6A/Blaster2 configuration on my 82' RX7, but it does not arc because the distributor cap is larger in diameter than my accord.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Never had any problems with arcing that I know of.
    As far as I know they are exactly the same exept the sci is good up 11000 rpm to the 9000 of the 6al
    Atlanta, GA
    Don't know, I might of had arcing problem. I did need to replace the distributor cap due to the points inside it disintegrating. Then again, it was VERY old.
    carotman's Avatar
    Montreal South Shore
    I 've been running the SCI with a Blaster coil 3 for the whole summer.. no problems have surfaced
    Texas Hill Country
    Thanks for the speedy responce. I was reluctant to install the ignition module on my accord for fear of arcing problems, but no longer.
    1988starter
    Guest
    I have had no problem but I would suggest 8mm plus wires to be safe extra insulation is good.
  1. ignition??
    By 88hondaaccordlx-i... in forum EFI Tech
    Last Post: 12-14-2006, 06:51 AM
  2. MSD Ignition Digital 6 Plus Ignition Control
    By 86hondadx in forum Restoration & Custom Fabrication
    Last Post: 09-19-2006, 09:13 AM
  3. Replies: 15
    Last Post: 07-11-2005, 04:45 PM
  4. Need Help With Msd Ignition!!
    By geesnow in forum Performance
    Last Post: 04-15-2005, 02:59 PM
  5. MSD Ignition ?'s
    By Sabz5150 in forum 3geez Accords
    Last Post: 04-08-2005, 08:10 PM
