Results 1 to 15 of 15
Thread: A series flywheel bolt pattern matches B series
    LX User clean87sedan's Avatar
    Jul 2011
    1987 honda accord lxi
    Puyallup
    Lightbulb A series flywheel bolt pattern matches B series
    Today I took my new flywheel to a local machine shop and left it there for them to check the balance and see if its good.
    When I got there he said i needed to bring a crank to do it but they had a spare B series (not sure if b20, 18, 16, etc.) but the bolt pattern matched up exact! the only thing was the little dowel pin hole in the flywheel didn't line up with one on the b series flywheel but there didn't seem to be one.
    Anyways.. wondering if this info has helped someone in researching this? I may do some research in my free time to see the differences between A series flywheels and B series and if a clutch can fit. If so it may help out majorly in getting lightened flywheels for us but don't think of it as so.. lol this could all be crazy talk.
    I will take pics when I go back to pick it up!
    It's not about what sandwich you can buy, it's about making one that's different from every other one.
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Re: A series flywheel bolt pattern matches B series
    b series is 220mm. But I did a little Google research and Get ready for this. D series Is the same.
    B-series flywheel? [Archive] - TheZCR.com Forums
    DOHC ZC 1988 clutch question [Archive] - CivicWagon.com forum
    hmmm if b series are the same as D, then i can find out this week seeing how i have a d and a series motor and flywheels sitting in my basement.
    Feb 2012
    89/accord/lxi
    From how I was reading it all. A cable tranny D series flywheel and clutch kit should fit. Their all saying that all single cams are the same. The only thing I see being different it the bolt holes for the pressure plate. So as long as that's the same your golden.
    cygnus x-1's Avatar
    Chicago area
    It would make some sense that the ZC clutch/flywheel would be compatible. That's the same transmission that we use for the Hybrid trans swap. I was just trolling Rockauto and the ZC also uses the same spline count on the gearbox input shaft, which is a good sign. But from '90 up everything is different. And the 88-91 Civic has a 20 spline input shaft. I suppose it *might* be possible to figure out some sort of bastard combination.
    C|
    Feb 2012
    89/accord/lxi
    Well the clutch will work. And I don't think that the hardest thing to find for are cars. Now if the pressure plate matches up then we're on the something. I'll have to take my stock plate I've to my buddy's house and see.
    Feb 2012
    89/accord/lxi
    OK I tried to put a 92 and up clutch and pressure with a stock a20 flywheel not even close. But the flywheels seem to be close but I can't get my fly wheel off to test it
    Jan 2014
    Many
    Thanks man. Will be curious to see what you find about the differences in the flywheels.
    Feb 2012
    89/accord/lxi
    Found out why it didn't work. 88 civic/crx has same matching clutch disk as ares. I was using 98 one lol. Now from digging more I've found that people are use 90+ flywheels and pressure plates with 3rd gen accord/2nd gen lude clutch disks for their Zc builds.
    So in short if you would like to upgrade you flywheel you will need a 90+ civic with matching pressure plate and a 88 civic clutch disk. I will test this out at a later time.
    Jul 2011
    Puyallup
    That's a lot to think about but of you want the performance parts for cheaper then the accord, it helps!
    Feb 2012
    89/accord/lxi
    Quote Originally Posted by clean87sedan View Post
    the clutch aren't much cheaper in some cases it the. This is all about performance this would give you more options for upgrading.
    Jul 2011
    Puyallup
    True like now we can use competition clutches that are made for d series and so many other options
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    now with switching the internals of the trans to b series. I was wondering if the internals for all b series are the same. not talking about gear ratios. more like main shaft and what not.
    now let me get this straight, stock 90 plus flywheel with matching pressure plate and the 88 clutch disc? which 90 and up? and can someone pull up some competition clutch part numbers for all the clutch parts? throwout bearing is the same?
    Feb 2012
    89/accord/lxi
    Right. Just use the stock tb. And I would look at act's website they less a shot load of options and they tell you what the maximum amount of tq/hp the stuff can handle
    Sent from my SPH-L720 using Tapatalk
  1. Replies: 40
    Last Post: 12-03-2005, 05:33 PM
  2. bolt pattern
    By 89accordex in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-29-2004, 11:27 AM
  3. What is my bolt pattern
    By Magny in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-24-2003, 04:58 AM
  4. bolt pattern
    By 92 ex-r in forum Classic Honda Community Chat
    Last Post: 05-18-2003, 09:36 PM
  5. Spoon B-series performace for A-series
    By A20A1 in forum Performance
    Last Post: 01-19-2003, 08:26 PM
