Results 1 to 20 of 20
Thread: help
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    help
    Can any help me id this turbo. It was a freebie and it in good working order. I just need a the flange for it to get my down pipe made. I know that's it's from ford. Its maybe a Borg Warner/IHI RHC6???? Any info is good info
    Re: help
    No idea, get a better pic of the stampings. But soze wise id say its somewhere around a t25/28. It will be quick power but not alot. Just go ahead and spend 200ish bucks on a cxracing/gsp turbo. They are solid peices as long as you have a restrictor and keep it under 15ish psi.
    Feb 2012
    89/accord/lxi
    Re: help
    I've thought about it but it's was free and had been rebuild less the 50 miles before it was taken off. So to save money for other things for the build I would like to make this one work. It will also make for a nice break in turbo.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: help
    You should sell it to me haha
    -Harvey
    Feb 2012
    89/accord/lxi
    Re: help
    Quote Originally Posted by 'A20A3' View Post
    trust me you don't want the headache. But once the foot work is done you'll have a better time then me finding they parts needed to make it work.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: help
    Looks like a T3 flange to me. I have a manifold hehe
    -Harvey
    Feb 2012
    89/accord/lxi
    Re: help
    yes so do I. This is more so about the of housing so I can make a downpipe. But I think I have have found what I'm looking for. Just waiting on a email to confirm.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: help
    Stingerperformance! They require a core tho. I guess they reuse the flange but weld a correct 3" downpipe to it. O2 bung welded on and everything
    Edit: I myself have the smaller IHI turbo I believe. Water and oil cooled. But from what ive seen these turbos arent too bad and should be pretty decent on a stock motor setup with a good clutch and tires
    -Harvey
    Re: help
    Dont bother with that size. Just get a t3/t4 now. Save urself the headache of getting new parts /new tunes now.
    Feb 2012
    89/accord/lxi
    Re: help
    So come to find out my turbo is off a subie. I also found a guy that will be sending my the file he used to make the flanges.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: help
    How much of a differnt tune with the SAFC are we talking?
    due to spool time being faster so you would need to be richer even lower in the band?
    I originally became interested in this turbo over the t3 60/63 due to the fact I wanted power before 3000rpm...
    -Harvey
    Feb 2012
    89/accord/lxi
    Re: help
    Dame here. Most of my buddy's running d series or single cam Honda are running them on stock blocks and make good numbers. 13's isn't bad for this little guy. Found What I've read this should be able to get to 250-300 HP range with out a problem.
    Feb 2012
    89/accord/lxi
    Re: help
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: help
    Mines a rhb52b I belive and its not on that chart...
    -Harvey
    Re: help
    Safc is simplest to "tune," but your only tricking the ecu's factory maps. reworking them makes it work the best/more efficient. its all case by case are far a fuel goes. and what are your plans with the car? you trade off low end power for higer rpm restrictions. small turbos can become a restriction.
    running what turbo making 250-300?
    and i found these for ya. I cant even find a smaller ihi rhc6 like what you have pictured?
    RHB5 vj11 turbo question? - Team Integra Forums - Team Integra
    Matt's IHI Turbo Page <p>IHI = Ishikawajima-Harima Heavy Industries.
    Big turbo, small budget. IHI RHC6 GM 1-8 - Mazda MX6 Forums: MX6 Forum
    Feb 2012
    89/accord/lxi
    Re: help
    This All The Same Info I Found But hmt.com Had A Lot More In For On These And Some Nice Build With them.
    So will my build keep in mind I'll have a fully built head. If Brodie for the FB group is pulling 150whp with just a milled down head, delta 272 cam, heaer, and a b16 itm. I don't see why I wouldn't hit 200+whp with this turbo. Yes it's gonna be all top end power but that's where you lose power with these engines anyways right?
    Feb 2012
    89/accord/lxi
    Feb 2012
    89/accord/lxi
    Re: help
    Where is the 250-300hp on with this turbo? Everything I see says its super small, great for traffic weaving (just like a t25) but becomes a restriction at 6k +.
    I keep finding max psi you can run being 13/15psi depending on the exact trim of the turbo. Im just trying to help ya build something with more room for improvement if you dont like it. Full boodt under 3k is cool but you will be in it alot more esp if u do hwy driving or live in a hilly area.
    Edit: even with a fully build head u wont be making alot of top end power if you have a small turbo that you are maxing out. The powerband with smaller turbos are in the 2500-5000ish rpm.
    Feb 2012
    89/accord/lxi
    Re: help
    I know what yours say but I don't drive the car but once a month in the streets if that the car sits because cail smog laws are gay. So for now I'm not gonna go any bigger tell the car tell motor is built and the bug's are worked out. My car is 100% a project/garage queen
