Results 1 to 7 of 7
Thread: Car sputters
    88 LX-i
    Mcallen,TX
    Car sputters
    When I would be driving the car would sputter when it would reach higher speeds and rpm's and the check enging light would come on. When I would push in the clutch and give it gas the check engine light would turn off and I could continue driving. Can this be associated with the Main relay. I know my main relay is bad since a few weeks ago. I resoldered the joints and it worked for awhile. But know the car doesnt turn on. Thanks
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Check the ecu code under the drivers seat. Count how many times it blinks and check with the FAQ.
    Oct 2001
    87 Accord EX , 5spd , Manual
    does it start fine ?? when cold / hot ?
    MIKE
    88 LX-i
    Mcallen,TX
    I think the main relay is shot becouse the PGM-Fi light doesnt come on and i don't hear the fuel pump. I have already tried soldering the dry joints. So i need to get a new main relay.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    i had that problem... i found a cloged fuel line. then i bought a weber and i solved every thing. oh shit... u have a LXi... ummm... check all metal fuel lines for clogs.
    Travis
    88 LX-i
    Mcallen,TX
    How can I check if i have clogged fuel lines?
    NORTH BAY ONTARIO
    im not sure on a FI car. look and see if they are crimped. thats the prob with mine. but on a carb car, you take the fuel line off and turn the key and see how much fuel comes out. Also it may be cloged injectors, weak fuel pump or some ignition prob
    Travis
  1. 86 lx-i sputters
    By ace69247no13 in forum EFI Tech
    Last Post: 05-20-2005, 03:51 PM
  2. Still Sputters!!
    By Scotts88WhiteLX-i in forum 3geez Accords
    Last Post: 06-22-2003, 08:05 AM
  3. Sputters wtf?
    Last Post: 06-15-2003, 03:52 AM
  4. car sputters...why?
    By superaccord in forum 3geez Accords
    Last Post: 01-28-2003, 12:38 PM
  5. Car sputters...
    By Nospeed in forum 3geez Accords
    Last Post: 12-12-2002, 10:05 PM
