Results 1 to 7 of 7
Thread: strange problem - fans not turning on
    DX User mesa's Avatar
    Feb 2014
    86 aerodeck
    hey guys, I have a strange problem, my fan is not turning on and that causes the engine to overheat when stationary.
    I have shorted the wires at the fan switch and that caused the fans to turn on so nothing else is the problem but I swapped the fan switch for a brand new one today and the fans are still not turning on :/ Anyone has a clue what the problem might be now?
    LX User LewZur's Avatar
    Jun 2008
    89 LX-i/90 Integra/92 LX
    RussVegas, AR
    Re: strange problem - fans not turning on
    Did you check the Thermostat to make sure it's opening?
    Darwin's rollin over in his coffin, the fittest are surviving much less often
    Feb 2014
    86 aerodeck
    Its all working fine when driving, it only overheats when not moving for a long period of time without having the inner heater on so i dont think the thermostat is broken. but I'm going to replace it anyways this weekend and clean the radiator and see if my crx' fan switch works as i know that the fans work on that car
    Feb 2014
    86 aerodeck
    well replaced the thermostat and flushed the radiator out just to be sure but nothing changed, the fan still doesnt turn on. im going to order a second fan switch tomorrow, hopefully that solves the problem
    Feb 2014
    1987 Honda Accord Lxi Hatch
    Did you check all relays and fuses?
    Feb 2014
    86 aerodeck
    Yes everything works, I kinda fixed the problem by connecting the wires going to the fan switch so now it turns on when the key is in position two, but its not how i'd like to have solved this problem
    quick summary:
    radiator flushed, everything seems fine
    new coolant
    new fan switch
    new thermostat
    new water pump
    new plug for fan switch
    fuses, relays, wiring all ok.
    i've tested the old switch in boiling water and that one also works fine so I really dont understand why the fan switch does not turn on.
    Check for faulty grounds, bad wires, etc. It's also possible that some piece of crud in the radiator is preventing the fan switch from getting a proper reading. Not likely though.
  1. Cooling fans not turning on automatically.
    By 1989accordaz in forum 3geez Accords
    Last Post: 07-19-2006, 07:17 PM
  2. Cooling fans not turning on, Missing plug on temp switch
    By Super_Blue_89LX in forum 3geez Accords
    Last Post: 09-28-2004, 10:58 AM
  3. strange new problem
    By hondamanlxi in forum Interior & Exterior Care
    Last Post: 07-16-2003, 03:23 PM
  4. strange noise when turning wheel!?!
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-27-2002, 08:44 PM
  5. Problem with cooling fans on Lx-i...
    Last Post: 07-16-2002, 09:29 PM
