Results 1 to 6 of 6
Thread: timing belt?
    Oct 2002
    1989 Accord DX
    Des Moines, Iowa
    timing belt?
    Driving down the street yesterday my car started to idle really low then it died. i thought it may have been the fuel filter because it seemed to not be getting fuel, i took the line off after the filter and gas came out so that wasnt it, i took out a spark plug and wire, i have a spark. So i took off the timing belt cover and My timing belt does not turn at all, and i called my honda dealer and he said it might be the bottom of the timing belt is bad... but that dont make sence. the top looks fine and it has the right tension. The belt goes arond there is no top or bottom. Did I not understand what he said or something? any suggestions on what it is?
    ________________________________
    Flip lid Intake
    HBK Spark Plugs
    Many More to Come
    10/Honda/Ridgeline
    NJ
    bottom of the belt i guess he was talking about the one with the teeth on em.
    Nov 2002
    1988 4Dr Accord LX-Burgandy
    Winnipeg, Canada
    Yes the belt goes around and there is no "top" or "bottom" BUT the belt has teeth on the inside that grip the teeth in the pulleys.There is a pulley on top attached to the camshaft and another pulley at the bottom attached to the crankshaft plus an idler in the middle on the right side that tensions the belt. You have most likely stripped the teeth off of the belt where it is currently going around the crankshaft pulley at the bottom of the motor. Hopefully that is all that is wrong and that you did not damage the engine when the belt broke. If the valves and the pistons meet it is not usually a good thing.
    Take it apart far enough to get a look at the whole of the belt and let us knwo what you find.
    Randy
    Oct 2002
    1989 Accord DX
    Des Moines, Iowa
    could someone please tell me the easiest way to get the timing belt cover(bottom) off?
    Flip lid Intake
    HBK Spark Plugs
    Many More to Come
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    pull hard... it should come off it you take out all the screws.
    Travis
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    yea thats what happen on mine a few months ago, the belt teeth stipped,
  1. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  2. Timing Belt
    By 89HondaAccord in forum 3geez Accords
    Last Post: 03-10-2005, 07:54 PM
  3. Timing Belt
    By 89HondaAccord in forum EFI Tech
    Last Post: 03-09-2005, 04:30 AM
  4. Timing belt
    By 89AccordLvr in forum 3geez Accords
    Last Post: 03-20-2003, 05:13 AM
  5. Timing Belt.....
    By 3G Jester in forum 3geez Accords
    Last Post: 01-03-2003, 12:06 PM
