Results 1 to 9 of 9
Thread: ignition
    DX User dray423's Avatar
    Jan 2014
    87 honda accord
    inman
    ignition
    hey guys I need help finding a upgraded ignition for my a20a1
    Re: ignition
    Could you be more specific?
    Re: ignition
    why do you want to upgrade? what are your future modifications? the stock system with good wires is pretty good, run NGK V powers which are factory specs. I'm running an MSD 6T with the soft touch rev limiter, I'm running it because I want a rev limiter, and I'm going to be running pretty high compression, along with other mods, so an upgraded ignition is important in that case. For a mostly stock setup, the stock ignition is good. Good wires will help, you dont need those super expensive Nolog..I mean bullshit wires, good NGK wires, or any good spiral wound wire will help, I'm running morosso mag cores, which are good quality without being overly expensive
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: ignition
    good quality plugs, leads, anew cap and rotor and a good coil will be fine.
    as long as the coil is one that is safe for electronic ignition you will be fine.
    the reason i say safe for electronic ignition, is that not all coils re created equal.
    the primary resistance varies quite a bit between points and electronic systems.
    to low in the resistance and the ignition module will overheat from high current draw and pack up, where a points system will take it
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: ignition
    Yeah, you really don't need to upgrade the ignition in these cars above a good tune up with quality parts. The next step would be to either go with an OBD1 setup or a Megasquirt or FreeEMS setup, in order of amount of work required. Do a search to get a feel for what's needed.
    Re: ignition
    if you do do any kind of upgrade, one of the new MSD digital ignitions are always nice, I'm running a GM blaster coil, thats the coil I've seen many others who have done serious upgrades, run. It has a well known good track record on Hondas. running a box also unloads the ignition module, it carries a lot of current normally, as it fires the coil directly, but if you run a box, it only acts as a trigger, and carries only milliamps
    Jan 2014
    87 honda accord
    inman
    Re: ignition
    Im am havein a block punched n rebuilt and a stage 2 cam with duble valve springs and a intake port n polish. my head is already ported I have a 32/36 webber with a set of obx long tube headders with a 2in exhaust to A obx muffler
    and thanks for the help everyone. and with the upgraded coil do I need a control module
    Re: ignition
    Quote Originally Posted by dray423 View Post
    I've seen the GM blaster coil run on a lot of built Hondas without needing to change the ignition module, one of the new digital MSD boxes would just give you options such as a rev limiter. Summit racing also sells their own brand, which is more then likely made by MSD, and has the same options. If you get the MSD GM blaster style coil you will need to get a plug off one of the original cars that came with that style coil, they should be common at the yards
    Re: ignition
    this is the one I'm talking about, should be good for your needs, MSD Ignition 8226 Blaster Ignition Coil | eBay you don't want to run the old style round coils, they tend to suffer from hysteresis loss towards 6000 rpm or so, they were fine for old american cars with lower revving V8s, but not so good for high revving engines, the stock coil on these cars is a U core like the MSD. what happens with the hysteresis loss, is your spark is created when power is interrupted to the coil, and the magnetic field collapses. with a round coil, the coil tends to retain some of it's magnetism, and as the rpm's go up, the coil becomes saturated and your spark voltage drops off dramatically, U shaped coils don't suffer nearly as bad from this
  1. ignition
    By allaces in forum 3geez Accords
    Last Post: 11-14-2012, 08:47 PM
  2. ignition box==hp?
    By newaccorddriver in forum Performance
    Last Post: 04-18-2007, 12:44 AM
  3. MSD Ignition Digital 6 Plus Ignition Control
    By 86hondadx in forum Restoration & Custom Fabrication
    Last Post: 09-19-2006, 09:13 AM
  4. Replies: 15
    Last Post: 07-11-2005, 04:45 PM
  5. Need Help With Msd Ignition!!
    By geesnow in forum Performance
    Last Post: 04-15-2005, 02:59 PM
