Results 1 to 10 of 10
Thread: Turn Signal LEDs!
    Jul 2009
    Somerville, Alabama
    Turn Signal LEDs!
    Well, i've been fascinated with LEDs for year, and the incredible fact that they consume so little electricity compared to the regular incandescent/halogen type bulbs our cars came with. I got so tired of watching my voltage gauge constantly fluxuate between 14.1-13.7 back and forth. All i did was replace the relay with a Tridon (Novita Tech Inc.) EP34 Electronic relay from advanced auto parts. This is an exact OEM fitting relay.
    These are the bulbs i came across to use. The glass really helps throw out light, yet focus it as well. I love this design and it's ridiculously bright at 3W each. They're CREE's .
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    Re: Turn Signal LEDs!
    Here is the end results
    Here is a link to the video of the light at night. Couldn't get it to upload on photo bucket :-(
    1986 Honda Accord HID 3W LED front turn signals: http://youtu.be/syUtyM_JqMs
    Sent from my GT-P3113 using Tapatalk
    Shaggy
    FF II/ETC I
    DX User mint89's Avatar
    Jul 2013
    (2) 1989 accords lxi
Size:  88.5 KB[EMAIL="undefined"]undefinedClick image for larger version.
    I made my own turn singal mirrors with LED lights
    Mar 2014
    2000 Honda Si
    United States
    If you don't mind me asking, how long did all of this take you?
    Jul 2009
    Somerville, Alabama
    Like less than 20 minutes with all I needed on hand. Total it was replacing the relay which was plug and play, 4 screws and four bulbs. Very simple easy process
    Sent from my SPH-M840 using Tapatalk
    Shaggy
    FF II/ETC I
    you should get a resistor to help slow the blinks down man. looks good tho!
    they make a specific blinker module for LEDS, sometimes even the electronic ones have the fast blink function, this is supposed to tell you that a bulb is burned out,if it was a regular bulb, it would blink wierd on that side
    Jul 2009
    Somerville, Alabama
    I replaced the turn signal relay first and made sure it worked fine with the stock bulbs before changing anything. Then I installed the LED bulbs and tried then. Same flash rate no matter how many watts the bulbs pull. That's the only con I've found with this module. I wish there was one you could literally set the speed via adjustment screw or something. That would be nifty. Either way, I love this new setup. I got to get better photos and video though.
    Shaggy
    FF II/ETC I
    This is the one I used, and my blinkers work just as normal.
    https://www.superbrightleds.com/more...asher/783/837/
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    I did the flasher mod on mine: https://www.3geez.com/forum/technical...ml#post1104893
    Edit: I am now seeing adjustable rate flashers available online too, with a handy knob sticking right out of the unit housing. I am hoping the factory-made unit has a more even on/off timing. If you mod an existing flasher you'll know what I mean.
  1. Turn Signal
    By Xaisk in forum 3geez Accords
    Last Post: 09-10-2010, 12:25 PM
  2. turn signal help
    By 1987AccordLx-i in forum 3geez Accords
    Last Post: 10-01-2008, 12:59 PM
  3. turn signal covers oem
    By xvok in forum 2geez Accords
    Last Post: 08-03-2007, 11:33 PM
  4. Turn signal replacement
    By bugzboy85 in forum 3geez Accords
    Last Post: 03-12-2004, 12:37 PM
  5. turn signal problem
    By jaminjames in forum 3geez Accords
    Last Post: 03-11-2004, 02:13 PM
