Results 1 to 13 of 13
Thread: 1st timer changing out tranny NEED HELP.
    Feb 2014
    1989 honda accord lxi
    Hey I have a 1989 honda accord lxi, MT, fuel injected and im swapping trannys out and wanted to know what to replace while I have it out and do I need any special tools to do the tranny job and if so where can I acquire them. Also as this being my first time changing out a tranny on my car by myself is it a good idea to do it by myself or should I get someone to do it.
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    Re: 1st timer changing out tranny NEED HELP.
    Both the input shaft seals for the axles. The rear main seal. Inspect the flywheel for cracks heat transfer warps etc. And also inspect the clutch. Imo, its 150$ for a new lifetime clutch kit and lifetime flywheel from AutoZone. If ya done do a clutch at least get a new clutch release bearing.
    LIFE IS SHORT, DRAG IT OUT!
    I had to buy a transmission jack to do mine. I couldn't get it to slide into the clutch otherwise. My advice is to have a helper, at least a better helper than I had, and take your time to wiggle the trans slowly home.
    x2 on the rear main seal, but make sure it's a new seal and not one that's been sitting on a warehouse shelf for 30 years. An old one will leak and you'll be sad.
    May 2012
    central Ohio
    Just wondering, does swapping a transmission require removal of engine or can this be done from underneath the car?
    Mar 2014
    2000 Honda Si
    United States
    These guys hooked you up already!
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    its quite simple. just make sure all the cables are off. I've had to change clutches twice and change the tranny it self once. I didn't have a cheery picker and did it from underneath by the time the tranny went out I was able to do it in two hours, and bench press the trans in place. pull both trans axels out and drop the trans mount then reassemble in the opposite order.
    Nov 2008
    spokane, WA
    edit: cv axels
    May 2012
    central Ohio
    Quote Originally Posted by 2000JDMsi View Post
    Huh???
    Quote Originally Posted by JohnBoy View Post
    Thanks.
    Quote Originally Posted by whoisazuz View Post
    A good jack and 2 jack stands is a must. The biggest problem is getting the large nut off the cv shaft to the hub. They can be stubborn and an air gun needed. I would make sure you can get this off before you get to deep into it.
    Lifting and aligning the trans back into position alone is challeging as well.
    Nov 2008
    spokane, WA
    every time I've ever done it I've never pull the cv axels off, just popped them out.
    May 2012
    central Ohio
    How? Are you saying CV axles can be popped out of the transmission without doing anything to create space for them to pop out? I can't visualize this.
    Nov 2008
    spokane, WA
    I didn't have a impact wrench at the time so I would just pop the lower ball joint.
    ^^^ This is my method as well and is chronicled somewhere in the manual. It saves a lot of time over wrestling with the spindle nuts.
  1. A/C delay timer unit
    By piter in forum 3geez Accords
    Last Post: 09-14-2013, 05:52 PM
  2. hit a snag changing tranny please help if u can
    By headbanger in forum 3geez Accords
    Last Post: 03-19-2010, 08:04 PM
  3. Part # for fan timer sensor in t-stat housing
    By vongiese in forum 3geez Accords
    Last Post: 05-17-2006, 09:22 AM
  4. How to hook up turbo timer to our cars??
    By adams86lxi in forum Performance
    Last Post: 04-13-2006, 11:23 PM
  5. I need a 1-3 sec delay timer circuit
    Last Post: 02-22-2005, 12:43 PM
