Results 1 to 5 of 5
Thread: 1982-1983 Accord Heater Valve onto 1979 Accord Heater Core/Box Retrofit
    LX User PDXAccord79's Avatar
    Aug 2010
    79 Accord 1.8L CVCC 5-Speed
    Portland, OR
    Hello everyone,
    So my heater core and valve started leaking recently and I had to replace it. Unfortunately I couldn't find a new 79-81 valve so I replaced it with an 82-83 valve. I didn't get pictures of all steps so read this start to finish before you do anything if you do it. I've had 0 leaks so far. Here's the process:
    Cut the bottom pipe down to make room for the valve
    Remove the old valve from the bracket and notch the bracket for extra clearance as shown
    Your stuff should now look like this
    Which allows the valve to slide right in
    The 82-83 valve should have almost all of it's bracket removed. Leave a ring so you can JB Weld it to the old bracket
    Aug 2010
    Portland, OR
    Re: 1982-1983 Accord Heater Valve onto 1979 Accord Heater Core/Box Retrofit
    JB Weld the valve to the old bracket
    Dry install the valve and check to make sure that the valve opens and closes all the way as the flap moves. Note that I also had to remove the left side of the adjustable bracket so the screw could be set far enough out for full travel. Click for super high res so you can fully see what's going on
    Put some new hoses and clamps on and it's ready to party. Click for super high res
    Good luck!
    LXi User 79cord's Avatar
    Melb, Aust.
    Great work!
    Aug 2010
    Portland, OR
    Thanks! The 82-83 valve is really easy to find on ebay and I think this is a good solution if your valve is all blue and nasty.
    LX User 1GCustomAccord's Avatar
    Jun 2008
    79´Accord,83´Lude,71´Nova coupe,83´Pontiac 6000,69 Mustang coupe,and many more rusted crap...
    PY
    I have an stock of those NOS valves...
    Good job btw!
    So many reasons why
    I won't be sending postcards
    From Paraguay
  1. Need 83 Accord Heater Control Valve
    By tumminello123 in forum 2geez Tech & Performance
    Last Post: 10-12-2010, 08:59 PM
  2. HELP! I need a 81 Accord Heater Valve!!!
    By 2ndGenGuy in forum 1geez Tech & Performance
    Last Post: 10-12-2009, 03:47 PM
  3. Heater core?
    By ChaseR in forum 3geez Accords
    Last Post: 10-16-2008, 07:49 AM
  4. heater core
    By backhatcher in forum 3geez Accords
    Last Post: 12-03-2007, 03:32 PM
  5. Heater Core??
    By omarsdroog in forum 3geez Accords
    Last Post: 07-19-2006, 02:42 PM
VigLink badge
