Results 1 to 3 of 3
Thread: 89 lxi key stuck in cylinder, can't push in to go to zero position
    DX User rebuild's Avatar
    Jun 2010
    89 LXi
    apparently Honda does not make these cylinders anymore. anyone find a different one they like? if the key is stuck and won't turn to the 'off' position, can I still just take the 6mm screws that hold the switch on the back of the cylinder off and push in that release and the cylinder slides out?
    Re: 89 lxi key stuck in cylinder, can't push in to go to zero position
    Quote Originally Posted by rebuild View Post
    I bought one from rockauto not too long ago.
    Jun 2010
    89 LXi
    how did you swap it out? can I have the key in position 1 and still remove the cylinder? mine is a 5 speed I forgot to mention.
  1. 4th cylinder taking on water, white smoke from cylinder and exhaust.
    By PDXAccord79 in forum 1geez Tech & Performance
    Last Post: 11-06-2012, 08:54 AM
  2. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  3. TDC and crankshaft key position
    Last Post: 02-17-2008, 08:12 PM
  4. Ported box position
    By X-1 in forum Interior & Exterior Care
    Last Post: 05-17-2007, 07:48 AM
  5. cylinder position sensor and TDC sensor
    Last Post: 11-28-2006, 10:29 PM
