![Quote](images/misc/quote_icon.png)
lostforawhile
there are supposed to be stock lude valve springs that can be swapped in, but I'm not sure which, but they are stronger. for handling, replace the worn out rubber radiius rod bushings with the moog ones, they upgraded the stock replacements to poly, much much better and cheap,also considered a stock replacement, moog also makes the problem solver tie rod ends with the grease fitting, much better then stock plus you can force grease through them after a race to flush out the grit, it says you can remove the dash, but can't gut the car? also it says you can't have flammable materials in the car, yet can't gut it? I would think you would have to remove the rear seats and the headliner, due to the foam. If you can take out the dash,the heat and AC box, blower etc, thats a lot of weight, do they allow you to remove the AC? I would think not being able to remove it would cause issues with releasing r12 in a crash
