carb
efiOriginally Posted by a20a1here is the way i bypassed the intake manifold heater.
The efi and carb engines have simmilar coolant ports in about the same area. You will find all needed ports on both water pipes and thermostat housings.
differences:
A20a3
- has the temperature guage sending unit on the thermostat.
- has 2 thermovalve valve/sensor ports
a20a1
- has the temperature guage sending unit on the intake manifold.
- has 1 thermo valve port
anyways:
R1 - goes to the radiator.
R2 - goes to the radiator.
T1 - is the temperature sending unit.
C1 - connects to c2 directly or with a coolant "t" connector if it is used by the heater core.
B1 & even b2 can be plugged if you don't want to use the heater core.
There is a small coolant port near the center of the water pipe that runs under the intake manifold and feeds the carburetor base... When removing the coolant lines to the manifold you need to plug the small coolant port on the water pipe... Also plug the larger coolant port on the water pipe that is closest to the water pump. You bypass the manifold by running a short hose looped from c1 to c2 , although you can run a much longer hose from the port near the water pump... All the way to the port on the thermostat housing and it will do the same job.
The choke on the carb will need some vacuum rerouting to work. You need to relocate the thermovalve b (vacuum lines # 17,18,19) to the thermostat housing... And remove the thermowax valve a. With the thermowax removed you must connect a vacuum hose from the secondary diaphragm directly to the carb and remove the vacuum "t" connector or plug all ports and convert to manual secondary.
If you get the lxi thermostat housing then you can also swap in thermovalve a (vacuum lines # 17, 25) that controll the cold vacuum advance... You'll also have a working temperature guage inside the car since the temp sensor is now on the thermostat housing and has access to coolant
Originally Posted by slavicthis thread is based on this prelude free mods page describing free or dirt cheap mods. I found it referenced on a prelude forum (can't find link right now) where they agreed that some of them worked and were worthwhile (coolant bypass, egr block, ignition timing advance etc.) and some weren't worth it (flapper valve mod-caused loss of lower end power).
Egr mod has a thread: block the egr ignition timing advance has been discussed here quite a few times, though i still don't exactly get which screws i need to loosen. I will be referencing only the coolant bypass mod in this thread and intend to post pictures and make it into a well rounded how to.
Coolant bypass mod consists of two parts (at least on a prelude). The first is bypassing the coolant flowing through the throttle body.
The second is blocking the fast idle valve. Though the fore mentioned mod page doesn't mention it, it has been noted on the prelude forum that bypassing the coolant results in rough idle which is reportedly fixed by blocking the fast idle valve. I don't know yet if it will have the same effect on a 3g, but my fast idle valve was idling the car at 2200 rpm when cold so i wanted to block it anyway.
bypassing the coolant line through the throttle body is a simple process of disconnecting the hoses that run from the water pump to the throttle body and from the throttle body back to the engine (actually to a t or rather +connector) at the ends where they connect to the throttle body and connecting the two hoses to each other.
replacing the two hoses with one longer one was not an option to me as the water pump side was highly inaccessible. If you know of a simple way to do it, please let me know.
The problem i ran into was finding a 5/16 hose connector. I looked at 11 stores, all major auto parts stores and some local ones, the home depot as well as local hardware stores. The only 5/16 connector i found was in a $4.00 asorted vacuum connector kit at auto zone. can someone advise me if it is ok to use a vacuum hose connector on a water (coolant) hose?
i'm running late right now, but i will update this thread at a latter time with instructions and pics of fast idle valve block which i achieved successfully. I just wanted to get this thread started. I would like to make it into a well rounded how to.
