Results 1 to 7 of 7
Thread: radio has mind of its own
    Oct 2002
    88 LXi hatch silver tan
    Cherry Hill, NJ
    when i had my stock radio in i noticed that sometime when i would go out to my car and find the radio playing without the key in the ignition. So i put a new system in and it still does it but now i turn off the cd player b4 i turn off the car so it doesn't kill its battery. Though the battery has not ever been drained The stereo playing with out keys has happend a couple times and probably has happened more but ive only caught it a couple times. I dont worry about it too much but i was just wondering if anyone has an idea as to why it does this?
    Mods:
    Kenwood Head Unit
    Kenwood 6.5's allaround
    Rockford 150s Amp
    Pioneer 12" sub
    Planned mods:
    6x9's mounted next to my sub
    maybe a 2 inch drop.
    Next Car: 1996 prelude vtec
    shepherd79's Avatar
    Falling Waters, WV USA
    there is a wire that connected to the ignition wire. in your situation the wire from deck is not connected to that wire. it is connected straight to the battery. you may want to rewire the hole thing.
    here is the link for the wiring.
    http://www.installdr.com/Harnesses/HA-Wiring.pdf
    it is PDF, so it will take a while if you have dial up connection.
    Oct 2002
    Cherry Hill, NJ
    thanx alot the help is much appreciated.
    Mods:
    Kenwood Head Unit
    Rockford 150s Amp
    Pioneer 12" sub
    Planned mods:
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    There is another inherent problem with the older Hondas. It is the ACC switch in the ignition has a tendency to die. It can go two ways, either the ACC position doesn't work at all or it is on all of the time. If you find that your wiring is correct, check that next.
    shepherd79's Avatar
    wow, i didn't know that. Thanks Bob.
    Oct 2002
    Cherry Hill, NJ
    Bob would the faulty ACC ignition switch also have something to do with why my car sometime wont start in park? Its starts fine in neutral but its weird because it happens so intermittenly.
    Mods:
    Kenwood Head Unit
    Rockford 150s Amp
    Pioneer 12" sub
    Planned mods:
    LX User Scotts88WhiteLX-i's Avatar
    Oct 2002
    88 Honda Accord LX-i Sedan
    Eugene,Oregon
    yea mine does the same thing i got a pioneer cd player an it will play even though cars turned off an keys out i have to press the off button on the cd player to make it turn off.
    -Scott
    88ancient
    -Its not illegal until you get caught-
  1. Fan Has A Mind Of It's Own!!!
    By azazel_18_2 in forum 3geez Accords
    Last Post: 02-23-2007, 09:25 AM
  2. se-i stock radio to aftermarket radio
    By 86_lx-i_hgreenIII in forum Interior & Exterior Care
    Last Post: 07-16-2004, 05:26 PM
  3. se-i stock radio to aftermarket radio
    Last Post: 07-11-2004, 08:05 PM
  4. Just Speaking My Mind
    By uneek in forum 3geez Accords
    Last Post: 12-10-2002, 05:51 PM
