Here's my new setup. 12" front and 11.1" rear I'm using the brackets that where custom made by rob to mount the front calipers and I'm using legend rear calipers. Stainless braided lines all around.
Pleas excuse the dirty car, Its been on jack stands for the past month.
You can also see the the addco rear sway bar DOES fit the sei brakes. I just need to go buy some shorter bolts for the end links. I was only able to run one bushing between the sway bar and the bracket but it shouldn't make to much of a difference.
I took it for a test drive tonight after i eyeballed an alignment, since i changed the power steering rack, and the brakes work great. I locked up all four for a second going 40+.
