Results 1 to 4 of 4
Thread: Slight engine tapping when cold...
    Ebony Black '87 Acura Legend L Coupe 5-Speed. Regency Red '86 Accord LX Sedan 5-Speed. Montreal Blue '87 Accord LXi Sedan Automatic.
    Denver, CO
    Guys,
    The new Accord sat overnight in the extreme cold, and when I started it up today it had a very slight tapping. Only happened when reving or holding engine speed, not when decelerating. The noise went away once it ran for a few minutes.
    I know these don't have lifters like the G1 Legend does, so should I be worried? Could the valves just be off?
    carotman's Avatar
    Montreal South Shore
    Re: Slight engine tapping when cold...
    Tapping under load might come from the rod bearings.
    What oil weight do you use?
    I need these parts!
    Denver, CO
    I'm not sure what oil weight it is, I just bought the car two days ago.
    I do know that the tapping goes away once the engine is warmed up.
    10w40 is about all these motors can stand in cold (below 32) weather. Make sure to let the car run a few minutes before it sees any load or rpm. I would not rev it past 3 grand until it is fully warmed up.
    You might also look at replacing your oil pump this might help the low oil pressure at idle.
  1. Tapping VSS for EFI swap
    By 2ndGenGuy in forum 2geez Tech & Performance
    Last Post: 01-03-2009, 10:27 PM
  2. Condenser Fan On, Engine Off and Cold
    By nutmeg_runner in forum 3geez Accords
    Last Post: 05-28-2007, 12:04 PM
  3. tapping sound
    By gp02a0083 in forum EFI Tech
    Last Post: 05-07-2006, 12:33 PM
  4. engine to cold?
    By LXi89 in forum EFI Tech
    Last Post: 02-09-2006, 07:17 AM
  5. Cold Engine
    By Accy in forum 3geez Accords
    Last Post: 10-17-2003, 12:34 PM
