Results 1 to 11 of 11
Thread: 1986 Accord 4 door LX with carbs - Fuel pump Access
    Nov 2022
    1986 Honda Accord LX 4 door A20A1 with 5 spd manual
    Vancouver
    Hello, I need to confirm my electric fuel pump is receiving power. The fuel pump relay is receiving power and also checks out fine, so I need to determine if there is a problem with the wiring to the fuel pump or if the fuel pump is bad,
    I pulled out the back seat and was disappointed to find there was not an access panel for the fuel pump. It looks like I have to drop the entire gas tank to access the fuel pump.
    Is there an easier/better way to access the fuel pump?
    Thanks in advance for any and all help.
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    Re: 1986 Accord 4 door LX with carbs - Fuel pump Access
    There's an access panel in the trunk, isn't there?
    Nov 2022
    Vancouver
    I just checked the trunk and found these two silver, round plates that measure 6 inches in diameter. They appear pressed into the body and held in with sealant. There is no obvious way to remove them, except to pry them out.
    Are these the access panels?
    Quote Originally Posted by Gunter View Post
    Yes!
    The one on the left is the fuel pump cover.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Yeah literally just pry it off with a screw driver, it's not pressed. It will probably stick right back on when you are done...
    Just watch out and don't get your sleeves in the glue lol
    Nov 2022
    Vancouver
    Thank you for the help guys. I really appreciate it.
    Download the manual top of the page it will help you get thru all this too.
    Nov 2022
    Vancouver
    I just downloaded both the Design and the General Shop Manual. They are **awesome**. They are 100 times better than the ALLData DIY subscription I pay for.
    Thanks again so much! Greatly appreciated!
    I hope im correct that the fuel pump is under the left cover, it is on FI cars I didnt see yours is a carb.
    AND just a warning the edges hole in the body are razor sharp! I cut my knuckle down to the bone on one of these videos I did.
    Nov 2022
    Vancouver
    I replaced both fuel filters. The primary filter is down by the rear wheel and looked like it had never been replaced. The secondary filter (under the hood) was easy to replace.
    I then replaced the fuel pump and it started up right away. It now runs like a champ again.
    Thanks for all the help!
    great news!
    Not to worry you but some of those pumps run a little to much pressure and may flood your carb time to time. If its running dont sweat it, just keep it in the back of your mind if you start having carb troubles like flooding at idle.
  1. 1986 Accord LX 4 door 5 speed manual with carbs
    By Gunter in forum Newbie Introductions
    Last Post: 11-20-2022, 12:40 PM
  2. '87 Accord LXi Gas Tank/Fuel Pump/Fuel Lines
    By peakylight in forum 3geez Accords
    Last Post: 12-06-2020, 07:56 AM
  3. 1986 Honda Accord lxi 4 door $$$
    By 88acclxi4dr in forum For Sale
    Last Post: 02-06-2015, 06:56 PM
  4. 4 door oem honda access rain visors
    By b20a86lude in forum For Sale
    Last Post: 12-09-2014, 07:34 AM
  5. FS - 1986/87 4 Door Accord Window Visors w/clips
    By Jumpsuit in forum For Sale
    Last Post: 11-24-2009, 11:01 PM
