Results 1 to 9 of 9
Thread: How to get rear stabilizer bush (innner)?
    Nov 2022
    1989/honda/accord 4dr super stage
    Japan
    I need real stabilizer bush.
    I can't find it.
    Anyone know where I can get the bush.
    Or Can fit other vhehicle's parts?
    I have 3rd generation accord.
    Sorry I can't write English well.
    Re: How to get rear stabilizer bush (innner)?
    https://www.3geez.com/forum/showthre...d-Install-Tips
    8401 Sway bar end links
    If you have the DX or LX you'll have an 18.5mm front sway bar, so you can use the 18mm EF sway bar body bushing which is part number 8-1106 and reuse the metal brackets.
    If you have the LXi or SEi you'll have a 22.5mm sway bar, for this you can use the body sway bar bushing from a newer model Toyota Celica which uses a 22mm sway bar. This kit comes with new brackets and I'll edit this later with the part number.
    8-1201 Front Strut Rod Bushings, this is that bar that bolts to the lower control arm and up to the front of the car under the radiator. If you have bad wheel hop, this is the most likely culprit.
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    He's in Japan, completely different trim levels there.
    Probably should correspond size wise. The fronts are Engery Suspension universal size.
    The rear is 13 mm if he has one.
    Nov 2022
    Japan
    Thank you.
    I need rear bush.
    My accord is accord superstage like LX grade. (engine size is smaller. A18A)
    Nov 2022
    Japan
    I am sorry. sedan type has NO stabilizer...SORRY
    Jul 2022
    Rhode Island
    Quote Originally Posted by cc2vigor View Post
    Thank you.
    I need rear bush.
    Huh, yours has pop up headlights. Very odd how certain trims/grades in JPN don't have pop ups and instead have the EU style headlights.
    Quote Originally Posted by RI86DX View Post
    Possible the 4 door being made here stateside they didnt bother with the change over.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    I've actually only seen about a few of the fixed beams, and they're usually in like Latvia or something. Every japanese 3g I've seen on insta has popups, but the fixed beams are definitely in the brochure
  1. How do i hook up a voltage stabilizer
    By Dat88Monstar in forum 3geez Accords
    Last Post: 03-05-2009, 08:56 AM
  2. fuel stabilizer, and 'storage'
    Last Post: 11-07-2005, 10:54 AM
  3. what does this torque stabilizer bar do exactly
    By T-Funk in forum 3geez Accords
    Last Post: 09-29-2005, 08:35 AM
  4. Question about Lucas Oil Stabilizer
    By rideredorgohome in forum 3geez Accords
    Last Post: 09-05-2004, 07:37 PM
  5. whats the blue marker on my BUSH, FR. ARM
    By gekko in forum 3geez Accords
    Last Post: 09-28-2003, 02:50 AM
