Results 1 to 14 of 14
Thread: Seriously doubt these kind of products
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    Lowering Springs. Do people actually buy things like this, does it work? I don't even see a spring rate spec. I just don't understand how products like this exist, I thought this kind of thing doesn't work
    Sprint lowering Springs 86 89 Honda Accord 1002 | eBay
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Seriously doubt these kind of products
    Why wouldn't they work? Most aftermarket lowering spring companies don't openly publish the rates of their springs. There's a handy guide on this board that lists them all, including these.
    Feb 2015
    Oregon
    Okay, I'll read up on it all. Because this would be cool, a nice option besides ksports or ground controls w/konis
    Feb 2015
    Oregon
    Dang, these are stiff! And super low..
    1999 Penalty Box
    The best way to do coilovers is to find a set of Koni Reds and have them rebuilt into Yellows. Buy a set of coilover sleeves off of eBay and throw the springs away. Buy a set of circle track springs from the roundy-round supply catalog, assemble, and have awesome suspension.
    No matter what, you will need at least Tokico Blues or revalved Bilstein Sports to handle any of the lowering springs available for these cars.
    Feb 2015
    Oregon
    I just did some quick searching and put together a setup of Tokico Blues, H&R Springs, SPC Adjustable Rear Upper Control Arm, and Cheddas Top Hats front and rear (~$940). With your experience, do you think that is sufficient, or are you saying the Koni reds to yellows and ebay sleeves w/circle track springs would be better for the money?
    1999 Penalty Box
    Going with coilovers allows you to change spring rates, adjust ride height, and lets you corner weight your car. If you don't care about playing with your suspension or corner weighting it, then a set of lowering springs will do you just fine. What you have listed is a good setup, but I'd spring for Konis if you can find them. Even running a set of used Reds is an improvement over Tokico Blues.
    Feb 2015
    Oregon
    Okay, thank you. I'm up in the air about it but I'll figure it out
    DX User carid's Avatar
    Jul 2014
    Honda Accord
    Cranbury, NJ
    Fixedit, aftermarket lowering spring really work and the one you've mentioned - Ksports is a great option. With this coilover kit you will be able to get 0.5"-2.5" Front and Rear Body Drop: KSport CHD240-AR - Honda Accord 1986 0.5"-2.5" x 0.5"-2.5" Asphalt Rally Spec Coilover Kit
    Quote Originally Posted by carid View Post
    1000 # front springs? That cant be correct.
    Feb 2015
    Oregon
    Yeah whoa..
    Also that's a bit out of my price range. I wanna be able to add tophats and adjustable control arms in the rear, even then I can't afford it. But 1008 pounds in the front? That hurts
    I think they have another set that 1200# comes with a free kidney belt.
    1999 Penalty Box
    That is one of the reasons why I suggest putting together a set of coilovers using Konis. It lets you pick the spring rate you want, and you get a good shock to control things.
    I have ran tokico with H&Rs and it was a nice sporty ride. A set of koni Reds could handle that big of a drop with that spring rate. the chances are rare that you will find a set of konis. I am running EF koni yellows with Ground Controls with custom spring rate because Im B swaped. I also have the Cheddas front top hat mod. I wish i would of gone with stiffer springs. so far im running 430 fronts and 315 rear. i feel like my front end needs to be stiffer. they can handle up to 500 so that would be my next upgrade.
  1. A few new possible products, Let me know!
    By hanginbyaccord in forum Performance
    Last Post: 10-10-2007, 12:13 PM
  2. Detailing products
    By Mars in forum Interior & Exterior Care
    Last Post: 04-10-2006, 04:17 PM
  3. Another motor swap doubt
    By RiCANACCORD in forum General Engine Swaps
    Last Post: 02-01-2005, 07:10 PM
  4. MOMO Products?
    By troutz15 in forum Interior & Exterior Care
    Last Post: 11-29-2003, 03:11 PM
  5. STP products ?
    By ACCORD EX in forum Classic Honda Community Chat
    Last Post: 07-14-2003, 05:06 PM
