Results 1 to 10 of 10
Thread: Which one of the following oiladapters should i use ?
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    I bought these two oilpressuresender adapters, which one would you guys prefer to use ? And why ? I am leaning towards the second one,looks more solid to me but i could be wrong.Any suggestions ?
    https://www.aliexpress.com/item/EPMA...420.0.0.bq3AUa
    BSPT to NPT Tee 1/8" Adapter Pressure Sensor Gauge Turbo Oil Toyota Lexus L-2Y
    Auke.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: Which one of the following oiladapters should i use ?
    Quote Originally Posted by AWH View Post
    Auke.
    The first one is an engine cooler sandwich adapter plate which looks like it just has 2 fittings for lines for the engine oil cooler radiator. And the second one is a turbo oil feed fitting. If you're just trying to add one oil pressure sensor you probably get away with a turbo fitting
    Feb 2017
    the Netherlands
    Both are also being sold as pressuresender-fittings.You can mount anything onto it as long as there is pressure i recon.
    Question was if there are clear pro's or con's to any of them in the sense of mounting,clearance,strenght or something like that.
    To the sandwhichplate i can also mount the oiltemperature-sender but i am a litlle weary of leaking,seems a lot to close off for just a single rubber gasket ring,is it not ?
    Auke.
    Feb 2016
    Florida
    Auke.
    If you have very little room under your intake manifold probably best to go with just the fitting. If you look at your other thread you started I posted a picture of a fitting installed but its for my oil turbo feed line. You would put your new pressure sensor where I have my Turbo line. Read through my thread it shows a lot of pictures of stuff you've been asking about
    Feb 2017
    the Netherlands
    Just what i wanted to see
    Thanks.
    Auke.
    Feb 2016
    Florida
    Thanks.
    Auke.
    here's a better look at it. $8 honda turbo oil fitting
    Feb 2017
    the Netherlands
    Can't open the picture to get a larger view.
    Could you explain to me where your oilfeed pickup is from and where your returnline connects to the engine ?
    Have you got a link of that fitting ? Can't find it on E-bay.Or just Autoparts store ?
    Auke.
    Feb 2016
    Florida
    Auke.
    its kinugawa brand. It's $12.89 on ebay. Sellers name authentic-boosting. I don't understand what you mean by oil feed pickup and return?
    Feb 2017
    the Netherlands
    Forget about it,my bad.Mixed things up
    Auke.
    Feb 2016
    Florida
    Auke.
    the oil feed and return lines come off the engine oil plate to a oil cooler radiator
