Results 1 to 14 of 14
Thread: Bee R Limiter
    DX User 86_Accord_Lxi's Avatar
    Jul 2018
    1986 Honda Accord Lxi
    NC
    Bee R Limiter
    Anyone installed a Bee R limiter on an A20A3 before? looking for a pinout of the ECU. thanks!
    '85 lude
    houston
    Re: Bee R Limiter
    Google around for honda helms download. There are multiple websites and a thread here.
    Jul 2018
    NC
    Re: Bee R Limiter
    been using google, couldnt find much so i turned here. thanks
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Jul 2018
    NC
    Re: Bee R Limiter
    thank you so much!
    Feb 2016
    Florida
    Re: Bee R Limiter
    Quote Originally Posted by 86_Accord_Lxi View Post
    thank you so much!
    No problem be sure to keep us updated get everything hooked up
    '85 lude
    houston
    Re: Bee R Limiter
    Ya, ive never heard of the thing before but def nice to have with high compression.
    Feb 2016
    Florida
    Re: Bee R Limiter
    It's a pretty good feature I like it. I've never used this box.but should help with not spinning the tires too much getting off the line
    Jul 2018
    NC
    Re: Bee R Limiter
    Do you have an ignition cut limiter or 2 step installed on yours?
    Feb 2016
    Florida
    Re: Bee R Limiter
    Both Two Step rev limiter launch control I use fuel cut though. I use it to hold the RPMs at a certain level for takeoffs. Mine is hooked up to a on-off switch when I go past 8 miles an hour it disengages
    Jul 2018
    NC
    Re: Bee R Limiter
    ah ok. im not seeing the pins i need to splice into on the pinout though. Click image for larger version.
    those are the wires on the limiter and what they do. handbrake is just a signal it uses to know when to actuate.
    Feb 2016
    Florida
    Re: Bee R Limiter
    RPM signal is going to be the blue wire in the engine bay to the coil
    Jul 2018
    NC
    Re: Bee R Limiter
    yep, just trying to be sure it will work before i buy it. i dont want to have a 250$ fancy box that does nothing lol
    Feb 2016
    Florida
    Re: Bee R Limiter
    Be sure to do some more research on it. For that kind of money it would be a good start towards a OBD1 conversion and have all those features and the ability to fully tune the car
  1. rev-limiter
    By 89accordex4dr in forum 3geez Accords
    Last Post: 08-16-2011, 07:20 PM
  2. rev limiter?
    By b8er in forum Performance
    Last Post: 08-23-2005, 12:35 AM
  3. RPM Limiter
    By TWOLOUDNPROUD in forum Performance
    Last Post: 06-02-2003, 06:47 PM
  4. rev limiter
    By guaynabo89 in forum 3geez Accords
    Last Post: 08-05-2002, 05:16 AM
  5. rev limiter
    By rallyeNate in forum 3geez Accords
    Last Post: 05-19-2002, 10:38 PM
Tags for this Thread
