Results 1 to 10 of 10
Thread: Fuel Filter? Fuel pump?
    Bass Man
    Guest
    I have an awkward problem with my 3g... I though I fixed it, but it just bit back harder.
    Starts up and idles awesome, but when I go down the road, I have to either creep up on the secondaries, or floor it... If I hammer down right to the top of my secondaries, I can kill the engine.
    Any Ideas?
    Re: Fuel Filter? Fuel pump?
    yes, dont do that !!
    thread title, coil, or float level would be my focus
    get a weber already, or find an efi donar car
    Bass Man
    Guest
    Lol. Don't do what?
    Brand new coil. I adjusted my float level, but I don't think it's keeping a good level.
    I wish I could afford a weber around here... Everyone wants them on their yota's and Sammy's... Webers suck off-road cuz they alway flood out... I might be able to get one off this guy I wheel with, but I think it's only a 32.
    I think I am gonna replace the rear fuel filter this week to see if that could be the reason.
    Bass its a carb. You can't treat it like its FI. You just got to be smooth with it and it will work for you. If your bringing your knee up to the steering wheel and stomping on gas pedal its gonna stumble.
    If its flat dieing it might be flooding the motor esp if you don't have the advance quite right.
    Bass Man
    Guest
    I wonder how the loose booster was playing a role in all this.... SOB!! I check that thing about twice a week and the time I think it's fine, it's so loose I thought it was gonna come off!
    Well, time to pull the tophat again... Hopefully it will be fine.
    It's the primary, and I am glad I don't have that choke crap on there anymore.
    Quote Originally Posted by Bass Man View Post
    Lol. Don't do what?
    don't under estimate the ability of the 32/36, if you can get a spacer to fit under them they do much better, problem is with these cars you would need a hood scoop, clearence is an issue. The flooding issue can be worked out with some modifications and a little skill.
    If i were a serious off roader without EFI, I would consider looking in to propane conversions, something you don't hear much about anymore but it used to be popular /
    Bass Man
    Guest
    It's getting more popular nowadays. www.gotpropane.com
    I have my hood off right now, and if need be, I will do FUNCTIONAL cowl modification... lol. No rice here, function.
    Definitely was my problem and it's all fixed now... Very nice acceloration and a LOT of pick-up. I still want a weber, though.
    I read about people filling some part of the webers up with solder to prevent them from stalling going uphill. The most common thing most sami owners do is turn the carb around so it floods downhill.
    I have read where you can fill up the power valve tube but I have not seen any real good diagrams. It is supposed to keep the power valve from enriching randomly to you can tune it properly with a wideband.
    cygnus x-1's Avatar
    Chicago area
    You need to talk to Sarge from this place:
    http://www.performancewebers.com/
    There is a box you can click on to mail him towards the bottom of the page. He is one of the primary participants in the largest/best/longest thread on DGV Weber carbs ever:
    http://forums.off-road.com/engines/2...er-38dges.html
    BTW, I have my Sami now and I'm doing the VW diesel conversion. Hoping I can try to start it up later this week.
    C|
    C|
    hahaa, I have already been reading Sarge's post on off road, EXCELLANT info
    I did not see that first link before yet. ON that off road weber thread he mentions setting up a dual progressive rig... I wonder if that ever materiallized.
  1. Fuel Assembly , Pump , & Fuel System Location
    Last Post: 05-10-2016, 01:27 AM
  2. fuel pump has pressure but not at filter!!!!
    By kyaccord in forum 3geez Accords
    Last Post: 10-15-2008, 10:39 PM
  3. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  4. Engine problems, maybe fuel filter or pump...
    By Trick87Accord in forum 3geez Accords
    Last Post: 08-08-2005, 07:03 AM
  5. hepl cannot got fuel line off fuel filter
    By 88vert in forum 3geez Accords
    Last Post: 02-04-2004, 09:20 AM
