Results 1 to 11 of 11
Thread: Difference between 1HG and JHM cars?
    Oct 2019
    1987 Accord LXi hatchback
    I'm wondering if I can use a dash harness from an identical trim car, same transmission, number of doors ext. But it has a JHM vin and not an 1HG.
    Sent from my moto g power (2021) using Tapatalk
    Re: Difference between 1HG and JHM cars?
    Probably if it's the same year/trim. Only difference I've seen is my J code car came with a Hitachi dizzy
    LX User RI86DX's Avatar
    Jul 2022
    Rhode Island
    Yup, and my Marysville car has a TEC.
    Oct 2019
    And so the car has a different part number and it is not interchangeable? If that's the case good to know if I'm ever getting one replaced.
    Oct 2019
    I'm hoping they used all the same boards. I was worried maybe in japan they had different pinouts since they might have had some domestic devices that they were modifying to USDM standards. whereas in America they might have started from the ground up on the circuit boards.
    I don't think you read what I just said... They are identical aside from a few interchangeable parts... However, trim levels and model years add options that can't be interchanged, so I would be more worried about that
    Oct 2019
    Thank you for clarifying man. This is the I answer I was hoping for.
    Jul 2022
    Rhode Island
    Don't J Vin cars have a different gauge cluster? As in, different manufacturer? Ohio ones have Nippon Seiki clusters.
    Nope, I've got a J vin cluster right here and there is an NS on the flex pcb (I don't have the og speedo though)
    Jul 2022
    Rhode Island
    Cool, reason I bumped the thread & asked is my entire speedo (speedo, trip & odo) died recently, Right before it failed I heard a pretty bad plastic clattering sound the last 2-3 drives I went out on prior to it dying...the needle would flip out near the number 20 and the faster I went the quieter it'd get & the more the needle would stabilize/act normal - starting to think it's a gear inside the cluster that conked out, not the cable itself. Still ordered a Pioneer CA3070 just in case though.
    Yeah, the reason I've got this cluster pulled apart is I'm putting eg gauges in it
  1. Replies: 2
    Last Post: 09-15-2022, 07:27 PM
  2. the difference between a dx and a lx
    By vojakd in forum Classic Honda Community Chat
    Last Post: 04-29-2004, 11:40 PM
  3. What's the difference
    By Morpheus in forum 3geez Accords
    Last Post: 06-07-2003, 12:19 PM
  4. Rims that'd fit on our cars from other cars:
    By gr3k0sLaV in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-13-2003, 09:46 PM
  5. Difference between DX, LX, LX-i
    By Versanick in forum 3geez Accords
    Last Post: 07-20-2002, 04:21 AM
