![Quote](images/misc/quote_icon.png)
Originally Posted by
Tomisimo
indeed 2ndGenGuy.. our engines have the biggest disadvantage in the head, the ports are just to small and valves cant give it enough air, the same goes for B20a, in edition it has 4 more valves but the ports are still to small. Valves capable of suporting 270Hp on those but only with head port ex&in sides.
Being a SOCH D16 is for the first its a short stroke engine, it just never will torq as A20. With proper headwork on A20 and stronger valves and if you manage to find cam bearings that are stronger it will rew up to 8-9k with no problems, just give it enough air.
My conclusion is that if you have 1k USD on B18, then 400USD on axles, 400$ on clutch converter etc etc. total 2-2500¤ to spend on a proper build, then you can just as likely spend that money on A20 and boost it, it will be cheaper and stronger engine overall.
