Results 1 to 13 of 13
Thread: 1989 Honda Accord LX smoke shooting out exhaust
    Apr 2022
    California
    I've had the car sitting for a couple months now since it kept overheating. I was getting a misfire as well at around 3000rpms. Car barely has 58k miles on it, but I'm debating either fixing it myself or selling it. I used the car as a daily for not even a full year. I love the car and I've had it since 47k miles so I want to keep it best case, but if its a lost cause then I might as well junk or sell it to someone who has the time and money to properly fix it. Any advice will help, I hate walking past the car everyday without knowing what exactly what I need to do for it. Thanks
    Re: 1989 Honda Accord LX smoke shooting out exhaust
    It probably has a blown headgasket, really not even a difficult one. Make sure the cooling system is in order, fans come on, thermostat works, no leaks, holds pressure, cap is good, etc. Whenever my headgasket blew it blew up 2 radiators (they started leaking around the bottom tanks). That could easily be the cause of the miss, but whenever mine starts missing, its usually the carb base gasket, which I just make out of gasket paper.
    White smoke in the exhaust, missing, and overheating are all classic signs of a head gasket. fwiw, they are pretty easy to blow in old hondas, usually fixed with arp head studs.
    LX User RI86DX's Avatar
    Jul 2022
    Rhode Island
    With only 58k on it you would be an absolute idiot to junk it....get it fixed/sell it to someone who will actually fix it and not give up and junk it. I'm curious as to why you let it get bad enough to the point where it overheated and ate the HG too. With a car that old with only 47k on it when you bought it you should have had the cooling system checked out.
    Quote Originally Posted by RI86DX View Post
    You don't have to do much to blow the head gasket. I mean the torque spec on the head bolts is like 60ftlb. Mine didn't blow for any particular reason and it's never overheated.
    Jul 2022
    Rhode Island
    Sounds like a similar story to the infamous Toyota Cressida/Supra HG thing from the same era....not enough torque spec on the head bolts from the factory.
    Maybe, but idk of anyone going over the factory spec on Honda head bolts. Arp studs are torqued to "god damn tight" though
    Apr 2022
    California
    My coolant runs out fairly quickly, like once a week needs a top up. Fans do come on but I feel like only when idle I might just be wrong though. Car leaks small amount of oil , not sure from what however. I was doing some research and always wondered if a gasket seal solution would help my case? Will a head gasket replacement fix the issue? Or the ARP head studs and the gasket? Thanks for the help.
    Apr 2022
    California
    Don't put head gasket sealer in it, it's just good for clogging cooling systems
    Gasket alone will solve the issue
    First i would do some testing.
    Do a compression test on each cylinder and take a look at the plugs.
    Apr 2022
    California
    Okay awesome, thanks for the help man. Plan is the replace headgasket n see if that stops the smoke and misfire. I'm thinking a new radiator would be a good investment as well while I'm touching everything else up.
    Apr 2022
    California
    [QUOTE=conozo;1226080]First i would do some testing.
    Do a compression test on each cylinder and take a look at the plugs.[/QUO
    I did actually change the plugs not too long before the misfire. Could the sparks still be an issue even though I just got them recently replaced? Maybe they're dirty from a leak? Idk, but thanks for the help I appreciate it, I'll definitely run a compression test on each cylinder and check the plugs.
    They could be dirty, but the miss might have gone away for a bit if they were a factor. You could also check the cap and rotor, and it wouldn't be a bad idea to get a set with brass contacts.
  1. Loving my first Honda: 1989 Honda Accord SE-i Coupe
    By fharding in forum Newbie Introductions
    Last Post: 04-10-2020, 12:45 PM
  2. 88 Honda accord LXI smoke from the steering column
    By Idontknow in forum 3geez Accords
    Last Post: 05-01-2016, 05:58 AM
  3. Am I the only one? -- 100% Honda Stock 1989 Honda Accord LX
    By TNTumbler in forum Classic Honda Community Chat
    Last Post: 03-04-2014, 09:56 PM
  4. Replies: 8
    Last Post: 05-01-2011, 07:15 PM
  5. Trouble-Shooting Honda Main Relay
    By Lester Lugnut in forum 3geez Accords
    Last Post: 06-06-2002, 12:44 AM
