Results 1 to 25 of 33
Thread: Raduis rod bushings..upgrade!
    Thumbs up Raduis rod bushings..upgrade!
    Well I changed my strut rods bushings out.
    WOW what a difference. The steering is more precise than ever. That little hitch I felt turning from a stop is gone too. I did not make any caster adjustments at this time.
    I used the TRW replacements. I measures there durometer at about 90-92 on an "A" scale where as the old original bushings were like a 40-45.
    The new TRW bushings are very very hard. You cant deflect the material by hand at all. I think the next step up from that would be solid bushings.
    Also I went to stainless steel braided brake lines up front but so far I can't say it made much of a difference as far as feel even though my old lines were original. I made sure about a week before to adjust up my drums in the rear while I was rotating my tires out. I didnt want to make a bunch of changes and not be able to tell if it was the brake lines or not. The only thing I added was the lines, new fluid, and of course a bleed job. I use castrol gtlma or what ever its called I buy it at Pep boys.
    Just some info to pass along.
    Feb 2004
    89 accord lxi
    down by the bay
    nice.
    where'd you buy them? and it's 2 per side, right?
    Quote Originally Posted by Strugglebucket
    nice.
    Adavanced auto so its that parts america website. They came with 2 bushing,washers and one sleeve in one box. So you need 2 boxes. I got the box at work Ill try and post the numbers.
    Quote Originally Posted by Oldblueaccord
    TRW #HB1597K
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Do you remember how much they were?
    Mike
    Vinny's Avatar
    Aug 2003
    Here, not there
    Mike, I know i picked up the Moogs from Rockauto.com and they were only 19 somethin plus shipping. they claim to be an "improved design"
    I believe the TRW's were 15 at advanceauto here in town.
    Oldblue, are those bushing black in color? The moogs are blue
    Vanilla Sky's Avatar
    1999 Penalty Box
    the moogs are poly... MUUUUUCH nicer than the stock rubber... if the TRW bushings turn out to be poly, that's good, too...
    carotman's Avatar
    Montreal South Shore
    Cool
    I might be able to get moog bushings here in Canada.
    Gota try and find out.
    I need these parts!
    Vinny's Avatar
    Aug 2003
    Here, not there
    if not locally you can always order them online , rockauto.com
    Dec 2003
    Millington, TN
    I just ordered a set K9517
    They are listed as "Strut Rod Bushings" No wonder I couldn't find them under "Radius arm bushings"
    $22.89 + $5.95 Shipping
    TRW has a lifetime warranty
    Moog only has a one year warranty
    Phil
    Quote Originally Posted by Vinny
    Yes they were black in color. I dont remember the price off hand sorry.
    Really made a big differance after a week of driving. car cuts in much nicer than I ever suspected it could. There no funny little power on wheel hop that i alway's blamed on stock struts and springs. I still might mess with the caster a little but I'm very happy and very surprised at the improvment.
    Not to thrilled with my Kuhomo ecxtas the fronts went to the wear bars in about 2500 miles. Thats worse than the Azenis sports and they dont grip as good.
    did you have the car aligned after bushings?
    I'm doing a half shaft on mine now and decided to to the bushings cause i feel it pull left when I accelerate. The new bushings are way harder than the originals. DId you do an alignment or did you put the rods back in without changing the adjusting sleeves? Do you think it will mess up the alignment?
    Well I changed my raduis rods bushings out.
    WOW what a differance. The steering is more precise than ever. That little hitch I felt turning from a stop is gone too. I did not make any caster adjustments at this time.
    Also I went to stainless steel braided brake lines up front but so far I can't say it made much of a differance as far as feel even though my old lines were original. I made sure about a week before to adjust up my drums in the rear while I was rotating my tires out. I didnt want to make a bunch of changes and not be able to tell if it was the brake lines or not. The only thing I added was the lines, new fluid, and of course a bleed job. I use castrol gtlma or what ever its called I buy it at Pep boys.
    Quote Originally Posted by jayshonda
    I didn't mess with the adjusting nuts but i took them out and anti-seized them up in case i do change my alignment. I have a lifetime alignment deal with firestone but there such retards there its prolly not even worth doing. I put the camber changers in there and when they saw I had 2 degress neagtive camber the guy freaked out and said I wouldnt be able to drive it They dont know how to change the caster unless I baby sat them and I doubt thats gonna happen so I might as well goto a regular owner operated shop and try my luck there. Just depends on how frisky i feel.
    Yes it did help with torque steer alot. Cant believe how much it helped really over all. Especially for how easy a job it is.
    The brake lines over all where a bust in my book. I should got em in pink to keep up with the bling bling Cali. guys.
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    we have torquesteer?!?
    anyways this looks like an interesting upgrade. Does the radius rods affect caster? I thought our caster was not adjustble on our cars...
    as for ss braided lines, I think they don't make a difference in normal driving. Definitely in more heated driving but then the pads would probably heat up more before you notice much of a difference.
    When I installed my rear disc brakes and ss lines all around, i noticed a difference but I can't say they are from only the ss lines. Perhaps SS lines don't make a big difference at all.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    The length of the radius rod is what sets the caster--shortening the radius rod will increase caster. Our cars are the last Accords with this adjustment. I set mine to the maximum and appreciate the difference.
    Mike
    Jul 2003
    93 civic
    San Francisco, CA
    so thats what that nut is for.. Thanks for the info mike! I definitely will look into getting new bushings and then adjusting caster.
    Nov 2002
    Ridin Dirty in New York
    do you have to buy one or 2 of the K9517 on rockauto.com? I need to change mine, my torque steer is out of hand
    Well the TRW ones I need 2 boxes. Not sure about rock auto.
    IMPORTANT: Do NOT reuse the nuts that thread onto the strut rod. Mine have come loose again. I believe the honda book calls for news ones. They must have a way to lock them on. I changed the oil the other day and one was way off and the other was loose.
    Nov 2002
    i think the originals are nylocs... and you gotta get those TIGHT
    Jan 2003
    1986 prelude
    charlotte nc
    instead of wasting ur money u shoudl of just bought the opm motorsports one ther3e better they are actually bearings
    Nov 2002
    bearings wear out, son
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    how much do you all think it would run to replace all the front suspension bushings. materials only. I was lookin at mine the other day and all the salt over the years has totally destroyed them.
    Quote Originally Posted by Ludi Mali
    I cant find the price atm but I think its under $30. The new nuts, I just added lock washer for the time being, but nylock nuts or what ever Honda sells cant be to much. Sorry I cant be more specific.
    Jan 2003
    1986 prelude
    charlotte nc
    re: upgraded strut rod bushings
    can i see pix
    whoa 05...lol
  1. Poly strut rod bushings, trim the central pin length?
    By BB_cuda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-31-2012, 11:36 AM
  2. Upgraded my 3G for a 350Z!
    By Night Rida in forum Classic Honda Community Chat
    Last Post: 07-19-2008, 05:57 PM
  3. urthane strut rod bushings?
    By lostforawhile in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-17-2006, 01:05 PM
  4. upgraded seats
    By Accordtheory in forum Classic Honda Pics & Videos
    Last Post: 07-09-2006, 02:35 PM
  5. New Rear Strut Bushings and Tokicos
    By possum in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-31-2004, 05:52 PM
