anyone attemped this on their 3gee???
I've been thinking about this for awhile, just want to see if its possible.
not worth it more 4x100 rims then there is 5 lug
im sure anything is possible thought dont think any one has ever done it cause its well kinda pointless on our cars
ok, whats the biggest rim we can fit on our cars???
I'm thinking 17x6 all around
Guy at Discount Tire found a set of 20s that would fit on my car. Bling bling yo. Who say you can't have a donked out 84 Accord. It would definitely be a sweet box. Do ya feel me, G?
oh man John I just threw up in my mouth a lil.
Ok, so yeah SOHC, you can fit 17's on your car. I've never seen 17x6, as the 17x7 or 17x7.5 are much more common sizes. Either way, the key is the offset on the wheels, and using the proper sized tire for our cars.
Can you do a 5-lug conversion? Absolutely, but I don't think any member has found a direct bolt-on 5-lug hub that works for the 3G. However, yes I know of at least one member that has 5-lug (at least in the rear), but that's not for street use.
In all reality, if you were to bring a set of hubs to a machine shop, they should be able to drill a 5-lug pattern into the hub and press in studs. I guess the only real gain here is the ability to use an OEM 5-lug wheel if you're dead-set on using that wheel. ...or if a set of wheels you insist on having are only available in 5-lug.
So far though, even if another member has wanted to do it, they have not yet done so. Maybe due to cost or maybe just the difficulty or time involved in doing it.
-Mark D.
Right on Mark, Thanks for the tip. I'll mostlikely use the 17x7`s. should be hard to find a decent set of new shoes for my car!
i woudl stick with a 16" your prolly gona have alot of probs plus money issues with the right tiers for 17"s
Shit anything bigger then 13 is an improvement for me Haha...
The 88/89 will roll on 14s though, thankfully.
i wish we could convert to a standard american lug pattern, i have these vintage 4 lug slots from the sixties here. 14s too. real mags
shit, my 3gee makes so much damn power.. i had to convert mine to six lugs..
one day I'll return.
^^^ Just look at the VW guys, many of them are 4x100 and get 5 lug bbs wheels re-drilled to the right bolt pattern. Many of them do it, and quite often. However if you really want BBS's, keep your eyes open... www.vwvortex.com classifieds and www.memoryfab.com you will find some, but they won't be cheap I warn.
Now to SOHC, 17's fit without a problem, just make sure you don't go wider then 7.5" and keep the offset fairly high as in +40 to +45 mm. As long as you do that, and get a 205/40/r17 tire you should be ok, many members have done it in the past.... I can't imagine you will be able to lower the car a whole lot without rubbing issues with 17's though, but I could be wrong.
My Project thread https://www.3geez.com/forum/project-c...dan-build.html
My Flickr: http://www.flickr.com/photos/jdmca5/
what about the 4x100 to 5x100 adapters?
very true on almost all of that but you CAN lower the car my buddies coupe was sitting atleast 3" down on those size tires with very little rubbing problems.. but his camber was not corrected, wich most likely helped a little...but the ride wasnt great and he constently had to avoid any little bumb in the road.. wich im guessing could get anoying... might be better set with some 16"s with some meat on the rim
on to the 5 lug conversion... kinda seems like a step in the rong direction if your only doing it for bling factor or rims... i could see doing it to fit bigger brakes but that can allready be done on 4x100's... so my question is why
I found a set of rims that where 5 lug, but I recently went back to the search and found a wicked set of 4 lug. 17x7. I'll try and find the 16x7`s though.
here`s a link to view the rims I found
BWT Rims 17x7 Black
i know the guys that do the h22 swaps use the 5th gen front end set up....that has a 5 lug swap
makes me wonder if johnny was still 4 luged making 500+hp
well you've seen how we all sit on 16"s lol
