Page 1 of 25 1234511 ... LastLast
Results 1 to 25 of 616
Thread: Rendons Offical A To B series thread!!!!
    Wink Rendons Offical A To B series thread!!!!
    Well im letting go of something good for something better LOL. ya ya i alread know what you guys gonna say Anywho
    I post pics once i get home.
    You guys know so far i have a B16a and I just bought a complete B18b1 last night. APr head studs and redo the main and rod bearing for a tighter clearance. 12 lbs should be 300whp.
    Pics to your comp near you.
    B series swap info:
    First off this project can be cheap, expensive, or nothing depending on your sources. But I'm going to give the info I researched an trail an fail lol.
    Motor: I'm Ls Vtec which means using a non Vtec block an mating it with a Vtec head. Now you can run non Vtec or Vtec up to you but I wanted a beast so I buildt mine.
    Wiring: I'm using a bloomslang jumper harness that was made for my chassis . You have to call bloomslang an tell em you want one made for a 86-89 accord. Only flaw about the harness is the ckp wires are not shielded which 2 bucks can get you the amount needed at Home Depot (shielded 18-2 wire) make sure you have these wires correct or you will not start. Harness uses your existing plugs as your AC solenoid connector for your iac an your fast idle control solenoid (in your black box as your) as your 12+ icm wire. Pretty much it an I took apart my engine bay harness an took out what I did not need an wanted an swapped plugs. You going to have to put a obd1 Ect,iacv,dizzys,Vtec (if have) tps,Iat, CONNECTORS on your existing harness. The jumper harness provides a extension harness to wire up (4) wire o2 sensor an extra crap if you have gsr with 2nd throttle body's. (pics in thread)
    Note: IF YOUR 86-87 an have a vss code (17) YOU NEED A 89 CLUSTER to fix this problem.
    Transmission: has to be cable unless you decide to swap clusters an do the required wiring to run eletro vss.
    Axles: have to use a mid shaft from 90-93 integra,gsr. Has to be female to male!!!!!!! Remember has to be that in order to run the axles I'm about to mention. You can use 94-98 teg mid shaft but you would have to a different seal on the cable trans. Also the correct axles for that midshaft.
    Driver - 89 lude (has to be this year not 90 or 91 those years have bigger hub which have a bigger shaft will not fit are hubs )
    Pass - 90-93 integra fits like a glove .
    Running this with no problems. All this hybrid axle crap makes no sense with this you can just buy one an swap it out.
    Shift linkage: you can just swap ends from a 90-93 integra (but I tryed that an was to long) my tip is to tack weld it an test fit it when it feels like it shifts fine . Burn it in. Install bastard pin an your set.
    Common facts: you need to be fuel injected an obd1. If your not this is the perfect chance to do it. None of your A20 parts will fit a b series so don't ask. This swap is not cheap so get a civic if you want a easy swap. If you can't basic tech work you shouldn't be working on a car period.
    Ill add pics an edit this once I get my Internet back lol. Pics are threw out the thread so start studying .
    Re: Rendons Offical A To B series thread!!!!
    Sweet! Can't wait to see the build man! PICS!!!
    Mar 2010
    88 lxi
    lawrenceville, GA
    im following bro
    88 lxi:
    Pics tonight guys . . But I got a feeling I'll be up in running soon
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    sweet, looking forward to this build
    -Gio
    My E85 Turbo Build
    5280FEST
    Oh snap. He isn't playing around!
    Mar 2010
    88 lxi
    lawrenceville, GA
    sooo the engines in already?
    88 lxi:
    LXi User oldschool3g's Avatar
    1989/Honda/Accord LXI HATCH
    somewhere in cali
    Sweet man can't wait to see pics of this beast lol
    Yup yoshi ain't playing. Got both motors. Need to buy apr head studs an Honda oem bearing.
    89T's Avatar
    Apr 2004
    Trader!
    un-motivated!
    3GR
    Aug 2009
    '13 Honda Civic LX
    Loudonville, NY
    So much win in this thread, can't wait to see pics
    Flickr | Facebook
    2013 Civic Coupe
    Trader!
    No no no. I still have an accord LMFAO.
    Quote Originally Posted by oldschool3g View Post
    Pics are your command LOL
    Quote Originally Posted by Mellexx View Post
    Pics are uploading as i type
    THIS!!!!!!!!!!!!!!!!!!!!!!!
    .PlUS THIS
    FORMULA is B16a Head + B18b1 bottom end with acl bearings and apr head studs = LSV WOOOT.
    OOOOOO BUT WAIT!!!!!!!!!!!!!!!!!!!THERE IS MOOOOOOREEE LMFAO.
    Tranny Mount
    Tranny Bracket Mount
    Back mount
    Left Mount
    Mock up on body. need to weld this mount.
    BUT WAIT THEREEE IS MOAAAR!!!!!!!!!!!!
    As you can see holes suppose to line up but they dont work. Thats why the mount isnt power coded
    Mount on the b series holes line up perfect.
    Things need:
    Tranny
    axles
    bearings
    Apr head studs
    Itr cams
    GE LSV convo kit
    89T's Avatar
    Apr 2004
    acl race bearings, use thicker racing oil. the clearances ar not as tight as standard bearings..
    un-motivated!
    3GR
    .0017 is ok I'm gonna plasti gauge before I order. What oil do u recommend bro?
    Aug 2009
    '13 Honda Civic LX
    Loudonville, NY
    Sweet tons of pics ftw, going to be so awesome once it's all in and finished up
    Flickr | Facebook
    2013 Civic Coupe
    Thanks bro. I like proof an pics. Pics are a thousand words lol
    Apr 2011
    What stiffness r the mounts I have the same ones but with red inserts wich r 95a n im putting a built b20v
    The track which is 85a which is plenty stiff
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Keep up the badass work!
    Thanks bro. Doing what I can with the funds I can get.
    Apr 2011
    do u know what outers to use for the spindles
    well a 3rd gen lud. 89 teg. are stock one. If anything ill pop the ends out and switch to what i need.
    it all depends what you use for a tranny.
  1. Tdurr's Offical Thread
    Last Post: 04-16-2011, 12:59 AM
  2. *!*OFFICAL*!* MUGEN thread
    Last Post: 02-11-2010, 07:39 AM
  3. $%# offical non-pop up head light thread#%$
    By ZackieDarko in forum Classic Honda Pics & Videos
    Last Post: 07-08-2009, 01:49 PM
  4. My B-Series Swap Thread
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 02-12-2009, 06:29 PM
  5. Reupholstery Offical How-To Thread
    By gr3k0sLaV in forum Interior & Exterior Care
    Last Post: 08-10-2007, 03:54 PM
