I’m still debating whether to attempt the timing belt replacement myself. After reading my Haynes manual, a few questions come to mind.
1) The manual says to unbolt the A/C compressor, setting it aside. From my perspective, the compressor is not a significant obstruction to replacing the timing belt. I can't see the need to unbolt it. Is this really necessary?
NOTE: My car has no A/C compressor belt on it; the compressor has been inoperative for a long time.
2) The manual says remove the alternator and bracket. Like the A/C compressor, I do not see the need to remove the alternator. As I see it, the alternator belt must, of course, be removed but the alternator does not have to be removed. Am I right, or does it have to be removed?
3) The manual says to have an assistant firmly hold a screwdriver in the timing viewport against the gear teeth on the flywheel to keep it from rotating during removal of the crankshaft pulley bolt with a socket and a breaker bar. I do have a very large screwdriver but I'm still wondering whether a screwdriver can really counter the force needed to break the pulley-to-crankshaft bolt loose.
4) One point that is not clear to me from the manual is the installation and tensioning of the new belt. I am under the impression that the lower timing belt cover would be replaced after the belt is properly positioned on the pulleys and that the final tensioning of the belt can then be done by adjusting the belt tensioner bolt (which goes through the lower timing belt cover). Finally, the top timing belt cover can then be replaced. Does this sound right?
5) Regarding removal of the left engine mount, the manual only mentions removing the long (horizontal) through bolt. But, in my view, two short (vertical) bolts need to be removed to completely remove the engine mount from the side of the engine. Am I right?
