Results 1 to 4 of 4
Thread: Relocating the battery for cold air intake
    Oct 2002
    89 accord lxi
    omaha
    Just wondering if someone could help me, or post a how to on relocating your battery when you do cold air intake
    10/Honda/Ridgeline
    NJ
    i have relocated the battery to the rear while my car is under construction for the whole mods list. anywayz, i got the box from summit racing cause it comes with everything and it ships in 3 days to ur house with ground shipping. the cables are 2 gauge for some weird reason so its gonna be a li hard to wrap them around anything, i got then running around the pass side floor under the mat scrwed and bolted in with some ghetto slyle screws. alwys remember to use the rubberized-undercoat to spray over the screws for a weatherproof seal.
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    Originally posted by smufguy
    . the cables are 2 gauge for some weird reason .
    voltage,electrical load and wire length ,3 important factors in determining wire size.
    as wire length increases,...resistance increases,....this can cause the conductor to heat....excessive resistance can heat it to a point where the insulation could melt,...with dramatic results.....even where the battery is mounted usually,...cables are quite thick,.....
    hope this sheds a little light....:smokin:
    10 sec 87 honda accord Lx-i
    Hamden,Ct
    Easy buy Moroso box ,comes with everything you need.Get a termial box for stereos and run cable from battery to it.Put everything from the positive termial on to it.
  1. relocating battery?
    By jamesh23 in forum Performance
    Last Post: 01-02-2009, 09:32 PM
  2. relocating the battery
    By KBs playtoy in forum 3geez Accords
    Last Post: 12-12-2004, 07:40 AM
  3. relocating battery to trunk
    Last Post: 06-26-2004, 09:13 PM
  4. cold air intake vs short ram intake vs intake
    By 89accordboi in forum 3geez Accords
    Last Post: 11-28-2002, 11:10 PM
  5. Relocating my Battery To the Boot
    By gr3k0sLaV in forum Interior & Exterior Care
    Last Post: 09-08-2002, 07:53 AM
