I need some help removing my ignition switch, apparently It looks like there 2 screws that hold It into place with the steering column, and there's no way to take them out. Does any one know how to do this.
If they are rivets, then you'll have to drill them out.
The part bolted to the cloumn is the ignition lock. The ignition switch mounts to the back if the ignition lock and can be removed without removing the ignition lock.
The bolts mounting the ignition lock to the column have heads that break when properly tightened. You have to grind them off.
The ignition switch has 2 bolts mounting it to the ignition lock you can usr a small wrench (I forgot the size) or a phillips screwdriver but you can blow a fuse if you don't disconnect the battery.
