ok on my left side I was replacing the brakes and I put the 2 new ones on and the caliper wouldn't go back down. It was like the brake pad was too wide or somethin, I know its not it's just that the caliper wont slide out enough to accommodate for the wider pad. the right side worked fine but this one is stuck or somethin. is there a way to take the caliper off from the rotor completely? because I need to fix it since right now I had to leave the outer old pad on and but the new one on the insid? why does it do this?
