Results 1 to 4 of 4
Thread: anyone know how to ge tthe front rotors off of a 5g?
    SEi User
    1994 accord coupe RIP/ 88 accord lx sedan, 99 Honda Prelude
    massachusetts
    i have a 94 accord lx coupe with abs and i have no idea how to get the front rotors off of it. it is nothing like a 3g or any buick i have ever worked on. if you have any ideas i'd really appreciate it.
    one of my 88 lx's is up for parts. good engine and transmission. pretty much everything is there. the fenders and hood are bad but other than that it's pretty good.
    RIP my beutiful 5g coupe. May the villans rot in hell!
    Nov 2002
    88 LX
    Nashville
    Here ya go:
    http://www.federal-mogul.com/fmeconn...loads/3501.pdf
    I ran into the same problem with my '94 EX. I've learned that the rotor doesn't always sit true on the hub, and a high speed brake vibration problem can be mis-diagnosed as a result. Taking the rotors off and having them turned will not solve the problem since the HUB is actually not true. The best approach is to find a brake shop with an "on the car" lathe, and it will compensate for the hub runout.
    Stock 5 Speed...
    385,000 miles so far. Many more to go...
    SEi User
    massachusetts
    ok. i figured out how to do it by just sitting with it for a while. but i can't get the lower ball joint apart. how do you separate the balljoint?
    Nov 2002
    88 LX
    Nashville
    Either one of two ways (or both):
    Take the nut off, flip it over, and put it back on far enough that it's flush with the end of the threaded portion. Then wail away at it from underneath with as big a hammer/sledge-o-matic that you can find.
    Or: Use a GOOD quality gear puller device. (two arms grab the knuckle while the threaded bolt pushes up on the ball joint). Do the flipped nut trick again, but this time leave a recess to capture the puller's point in. Make sense? Then you tighten it slowly and wait for the BAM!!!
    Stock 5 Speed...
  1. who else is using 12in front rotors
    Last Post: 03-24-2009, 08:55 AM
  2. upgrading lx front rotors
    By powderkey2 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-08-2006, 03:28 PM
  3. how to remove front rotors?
    By timber_cruiser in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-06-2006, 01:20 AM
  4. bigger front rotors
    By LIL'LXi in forum 3geez Accords
    Last Post: 11-08-2002, 04:41 AM
  5. Those damn front rotors
    By pimp86LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-11-2002, 07:40 PM
