It's getting harder and harder to get my key out of the ignition! Sometimes I have to start the car again, back it up, drive around, try and get the wheel in a different position. Sometimes I can just crank the wheel a half turn in either direction and it will release the key.
When this happens, I also cannot put the car into drive or reverse because the automatic transmission lock will not disengage, even when the car is started and the brakes are applied. I have to use my spare key in transmission lock slot to get into drive.
Any help would be cool because it's -35 degrees celsius today (as in, real f*cking cold) and I don't want to be outside taking things apart when I don't know what the problem is.
Thanks, guys.
