Page 1 of 3 123 LastLast
Results 1 to 25 of 69
Thread: B18A Intake Manifold on A20A
    86 Lx-i Hb.
    sAcramento, CA
    Exclamation B18A Intake Manifold on A20A
    need answers and clarification.
    -b18a manifold fits with drilling.
    -how would you go about the vacuum hoses and such?
    -would you plug it up the same way it looks on the a20x manifold?
    -has anyone done this allready? who? pics? how to?
    thanks. i allready have the b18a manifold and its sitting at my dads gerage right now. any info would be nice on how i would go about doing the swap. flame get mad. tell me to search. say whatever. but ive searched and nuthing has came up on how to do it.. just came up on 'if you can or cant' . thanks - junior -
    - J u n i o r -
    Quote Originally Posted by 89ACCORDVTECH
    - One of my carS is an SEI A20 my LXI has AN H22
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    to see how well it will fit, get a intake manifold gasket for the accord, and then put it on the end of the b18 manifold to see where holes would need to be drilled and stuff, make sure the ports line up correctly(although they'll be a bigger diameter on the manifold). as far as hooking it up and will it fit.., i'm not entirely sure..., haven't done this yet.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    86 Lx-i Hb.
    sAcramento, CA
    Quote Originally Posted by maka_RTH
    yea ive read so many posts about the gasket thing lol. but none about actually doing it or beyond the gasket part. if the b18 manifold has bigger ports. . should i just port the head to match up to the manifold also?
    - J u n i o r -
    Jul 2004
    Quote Originally Posted by bboipinoy112
    hey greets about the intake manifold i did it like a week ago and its pretty easy you only have to drill 2 holes a little lower from the stock ones from the runner #1 and the #3.its pretty easy cause ell the other holes lines up.here is a pic for u to usi for a reference
    Jul 2004
    i forget to tell that mines is from a b18B but its the same.
    P.D-sorry me english
    86 Lx-i Hb.
    sAcramento, CA
    holy jesus ... what about the vacuum lines?
    - J u n i o r -
    LX User geesnow's Avatar
    Jul 2004
    1988 honda accord lx-i
    richmond, VA
    do u notice any power gains??
    Check out my family site: mysite.verizon.net/vze8kudg
    maka_RTH's Avatar
    Nov 2001
    Orem, Utah
    as for the bigger ports on the manifold, you can just get you head port-matched for the manifold. this is recommended anyways for optimum flow. and if you got the money, you may as well get your head port and polished at the same time, along with the intake manifold.
    Greg
    10/Honda/Ridgeline
    NJ
    okay, if your worried about your vaccum lines, here is the solution. Get one of the vaccum distribution units. Its a big ole round thing with places for you to plug in hoses. You will have to get some "T" connectors and go from there, if you dont wanna spend big bucks.
    Jul 2004
    Quote Originally Posted by smufguy
    That's exactly what i did use 2 T's for all the vaccums.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    um, i thought it was a bad idea to port out the intake part of the head because honda makes them in just a way that it helps mix the air/fuel mixture. If you port out the intake ports, dont you have to 'texture' them to make sure it works like its supposed to?
    Nothin' 2 Old Racing
    10/Honda/Ridgeline
    NJ
    you port match it to the manifold, never on the head. but if a quality head work is done where oversized valves and longer valves with cams that have higher duration and greater lift will compansate for it. but like caleb mentioned, u dont wanna blindly mess with the intake side of the head, be careful how much u take off and just polish the crap outta it.
    '85 lude
    houston
    im actually about to do this too. honestly you dont even need to drill the 2 bolts. all the other bolts are fine and more than enough.
    after i rebuilt my motor i didnt feel like fighting to get the bottom bolts, so i left em off, had no leaks or probs now for almost 3000 miles
    10/Honda/Ridgeline
    NJ
    for NA you should not have problems with it leaking. But under boost. Well u are better off doing everything right. Also, Drilling the extra holes is not a pain, just mark them right, take it to a drill press or a mill and ur done in about 15 to 20 mts.
    86 Lx-i Hb.
    sAcramento, CA
    DAMN!. . getting our intake manifold is a bitch.... arg gar garr ! . but its off. 4 hours of fun. now i know how to take it off with out pain next time. maybe still pain, like busted fingers and chunks of skin taken off do to stupid 10mm bults that are tight as hell... why are the 10mm bolts harder to take off then the 12 14 17 19s ? anyways. yea... there is alot things going on when taking the manifold off. but hey. the intake manifold is going in.
    edit- snap-on tools are the shit. everyone should go buy some. replace your peice of shit craftsmans with snap-ons .... oh and swivel sockets and rachets are the SHIT!.. basic swivel socket and rachet set, couple extensions(3in,6in'rs), saved my life. if i was stuck with the ORDINARY tool set . . . who knows
    - J u n i o r -
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Yeah certainly get the distribution unit... or make one out of a 1/2" - 5/8" pipe with little 5/32" nubs for the vacum lines... It should get rid of problems caused by diminished vacuum signal.
    10/Honda/Ridgeline
    NJ
    with the top torque rod outta the way, it should take u no less than 20 mts to pull the manifold out. Atleast thats how long it took me when i had to change the gasket.
    86 Lx-i Hb.
    sAcramento, CA
    hMmmm. well. it coulda been faster. but it was at my pace of sitting and talking. and getting a bolt off and then talk again. so yea.
    - J u n i o r -
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    im curious to see the gains with a stock b18 manifold. I have considered an aftermarket manifold myself.
    86 Lx-i Hb.
    sAcramento, CA
    im curious also. when i ran my car at the tracks with shortram, monza muffler and no weight red. i hit 16.7s-8s. so yea. after this swap with the hybrid integ tranny. i will head out to the tracks on the 13th. and we will see what the 2 swaps will do together.
    - J u n i o r -
    86 Lx-i Hb.
    sAcramento, CA
    how much HP do you think it will bump me up, if any ?
    - J u n i o r -
    10/Honda/Ridgeline
    NJ
    i guess you guys did not follow up on search the old threads. cause this was already discussed. The power gains are hard to say if you dont have engine mods, like a camshaft, more fuel and other stuff. This is because, the B series manifold is designed for making power in the higher rpm, where these B series motors make their power obviously. So u will loose a lot of low end, i mean a lot. This swap on the manifold is only advised if u got motor work done with a rebuilt block, worked on head, cams, high cr pistons and what not to utelize this manifold. BUt for forced induction, this is the way to go.
    89 LXI
    Maryland
    Actually, you won't loose that much low end and if you think that you've lost too much there are was of compensating that... I run a b16 mani. but I also have the works done to my engine so I might not be able to give a fair accessment for the stock guys... I can tell you this, you will definitely feel it on the top end... The car feels like it will pull for days....
    LX User Swap_File's Avatar
    Manual 89 Se-i Accord
    Minnesota
    Re: B18A Intake Manifold on A20A
    I found a B18B at the junkyard, and grabbed the intake. Here are pictures of it next to my extra A20A3 intake.
    Note the two locations that need holes drilled, and note the one bolt hole and two coolant lines that would be unused.
    Minnesota
    There is a limit of 10 pictures per post, so here are the rest:
    Notice how the B18B intake dips less than the A20A3 intake, and it also ends up being taller.
  1. PROJECT: A20A to B18A Tranny Adapter Plate
    By SQ is the SQUAD in forum Restoration & Custom Fabrication
    Last Post: 04-30-2024, 10:38 AM
  2. Replies: 0
    Last Post: 08-27-2011, 02:44 PM
  3. victor x intake manifold modded for a20a/b20a
    By mykwikcoupe in forum For Sale
    Last Post: 07-17-2011, 12:47 PM
  4. b18a skunk 2 pro-series manifold.........
    By 89T in forum Performance
    Last Post: 05-13-2006, 10:58 PM
  5. B18A manifold -----> A20A head
    By Sabz5150 in forum Performance
    Last Post: 09-24-2003, 06:21 PM
