Well I bought an 89 Accord front bumper and decided to get a lip for it. Here's what you do. I didnt want the lip to cover up the bottom part of the bumper, so I used rubber grommets to set the lip a little lower. You can decide what size grommets you need (also figure out how long of a bolt you need), depending on how low you want the lip to sit.
Stuff needed
88-89 Front Accord Bumper (coupe or hatch)
88-89 Integra front lip
6 Bolts(you decided the size
6 Washers(you decide the size
6 Six Nuts (you decide the size
6 rubber bushing (you decide the size
2 Screws
Tools
Socket set
Drill (drill bit needs to match the bolt size)
Phillips head screwdriver
First mount the driver and passenger side exactly how you want it. Then drill the whole for the bolt to go through. Use the washer to hold the bolt to the lip and the rubber grommet to set the lip a little lower. Put the nut on the bottom of the bolt.
Now Mount the middle point of the lip I used a dowel to set the lip just a little lower, because the middle set to high . Mount exactly the same way as the driver and passenger side.
Now choose other points to mount the rest of the bolts and make sure the lip is even.
Set the lip exactly how you want and make sure everything is tight.
To remove the bumper check this thread Bumper removal: DIY
