i finally came to a conclusion that im going to run with MS/BTM for my management setup. ive got a few questions on it though.
i only want to use megasquirt as a piggyback fuel controller, or something like that. i only want it to control fuel outputs and such while ill hook up the BTM to it and thatll take care of my timing. if i hook it up as a piggy back and disconnect all 4 of the injectors and hook them up to megasquirt, i know ill get a CEL. also, as soon as my stock map see's boost, itll give me a CEL(it makes no difference as MS has a built in map sensor which ill be using).
my question is, would the stock IACV be able to operate under my stock ECU? id like to use megasquirt, but ive got a heavy foot, and i dont really wanna push the gas pedal everytime i back up into something. id like to know if the IACV and the ECU would still be able to hold a steady idle speed if i put some load on the engine.
